Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Clinking noise after autox!
Old Aug 23, 2004 | 05:43 PM
Andrew 825SM's Avatar
Default Clinking noise after autox!
After autocrossing at Hollywood Park, which has a very rough terrain, I noticed my car would make clinking noises under deceleration and my shifter would shake violently if it was left in gear. The higher the speed I decelerate from, the more violently the shifter would shake and the more rapid the noise would occur. It sounds like the clinking noise is coming from the driver's front side, but I am not totally sure. I just know its coming from the front end of the car.
I've checked the suspension and shifter linkage and have not seen any apparent damage. I thought it was my lsd, but found out that it was not after I jacked up my car and rotated one wheel to see if the other wheel rotated in the other direction. I'm hoping its nothing too serious.
Old Aug 23, 2004 | 05:54 PM
ewaugh's Avatar
Default Re: Clinking noise after autox! (Andrew 825SM)
what kind of car and what have you done to it, other than turbo?
Old Aug 23, 2004 | 06:23 PM
edlocke's Avatar
GSR w/Turbo? LSD? AutoX? If it tends to do it more while turning, get some new axles w/ beefier CV's soon or you'll be stranded at an event. Don't ask how I know.
Ed
Old Aug 23, 2004 | 06:42 PM
Default Re: Clinking noise after autox! (ewaugh)
It's a 2000 Integra GSR with a greddy turbo kit, suspension, lightened flywheel, clutch, and lsd on Azenis. And it doesn't do it more when its turning.
Old Aug 23, 2004 | 06:49 PM
KaBlammyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrew 825SM &raquo;</TD></TR><TR><TD CLASS="quote">After autocrossing at Hollywood Park, which has a very rough terrain, I noticed my car would make clinking noises under deceleration and my shifter would shake violently if it was left in gear. The higher the speed I decelerate from, the more violently the shifter would shake and the more rapid the noise would occur. It sounds like the clinking noise is coming from the driver's front side, but I am not totally sure. I just know its coming from the front end of the car.
I cant help you, but I want to say, I know your pain. I sometimes I hate racing there! Its like off roading!
Old Aug 23, 2004 | 09:51 PM
chibitank's Avatar
Andrew, this is Tetsu from auto-x.
u might want to check your motor/tranny mounts.
kinda sounds like same prob. i had at about 100,000 miles.
if bad, replace them with mugen or type-r mounts. i used typr-r w/ engery inserts. might as well upgrade while ur at it!
FS: brand new cusco rs diff. for b-series. $750
89brokendownEF
Jul 6, 2017 10:44 PM
tilhasbb
15
Jun 3, 2008 05:40 AM
SleepnCiViC
Feb 2, 2004 12:36 PM
