Aftermath of a mis-shift :(.
Here is the motor with it's Toda pistons before the tragedy:
After an unfortunate 3-2 shift at 9,000 rpm
Finally, after Dan Benson resleeved the motor and IB Jeff hooked me up with some pistons
Car is up and running as strong as ever. Time for a trip to the dyno
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">
woww!!!
nice rebuild
woww!!!
nice rebuild
only 9k? and it did that? what caused it....i shift at about 9,800k when i drag and havnt done anything like that yet...or were you at 9k when you hit 2nd instead of 4th?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si »</TD></TR><TR><TD CLASS="quote">only 9k? and it did that? what caused it....i shift at about 9,800k when i drag and havnt done anything like that yet...or were you at 9k when you hit 2nd instead of 4th?</TD></TR></TABLE>
yes he mishifted. didnt read the title of the thread?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDABROMANDUDE »</TD></TR><TR><TD CLASS="quote">Was this in your ITR?</TD></TR></TABLE>
Yes.
Yes, hit second instead of 4th. I figure the engine hit at least 12,000 rpm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">That mis shift must of costed you a few dollars.
Less than you might think
Yes.
</TD></TR></TABLE>Less than you might think
It is funny how the piston hole is the perfect shape of the number 1.
Anyway, that is terrible. Hope the new motor works out well for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prostockcrx »</TD></TR><TR><TD CLASS="quote">wow
how long did you run the motor after the mis shift? or did it just die right away.
From the looks of it, death was instantaneous
how long did you run the motor after the mis shift? or did it just die right away.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 »</TD></TR><TR><TD CLASS="quote">
i've seen plenty of burned and shatered pistons before, and to me it looks like he drove it home, then to the bank and then to benson's, i'm suprised the wrist pin didn't pull out and shater the piston,
ohh well the new motor looks awsome
</TD></TR></TABLE>i've seen plenty of burned and shatered pistons before, and to me it looks like he drove it home, then to the bank and then to benson's, i'm suprised the wrist pin didn't pull out and shater the piston,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone »</TD></TR><TR><TD CLASS="quote">Damm Todd , you own more motors than I have dyno passes.</TD></TR></TABLE>
lol. I wish. I am down to only three blocks.
Two for the Civic and the motor pictured above for my Integra. And I only have two good heads left, three if you count the one Brad has. The head that was on the car when I mis-shifted is scrap.
And you know I will post numbers when I hit the dyno, Jason
Death was instantaneous. Huge cloud of smoke and the engine died. Would not crank. Clutch was toast too-would not shift. Was in South Central LA when it happened
</TD></TR></TABLE>Death was instantaneous. Huge cloud of smoke and the engine died. Would not crank. Clutch was toast too-would not shift. Was in South Central LA when it happened
new definition of bad day
NO rev limiter?
NO rev limiter?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett »</TD></TR><TR><TD CLASS="quote">It is funny how the piston hole is the perfect shape of the number 1.
Looks like the we-todd salute to me! Man that is one ugly piston.
At least your car wasn't going to get stolen that day!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec »</TD></TR><TR><TD CLASS="quote">NO rev limiter?</TD></TR></TABLE>
A rev limiter is no use on a miss-shift. The ole motor looks good as new though.
Mechanical over-rev. Shifted from 3rd to 2nd. Rev limiter only cuts fuel, while going into the wrong gear puts the weight of the car into the over-rev. I've done it, probably most road racers have at one point
-Chris
-Chris
