B20 crank in b18b
Old Dec 3, 2001 | 05:48 PM
InfamousRS's Avatar
Default B20 crank in b18b
I know, I should have probably researched this before asking, but....
Is there any major differences in the b20 over the b18 besides the crank? If you used a b20 crank in a b18b, what rods and pistons would you use? Any info on b20 and b18b stuff would be great. Thanks
Old Dec 3, 2001 | 06:06 PM
1.8EG-T's Avatar
Default Re: B20 crank in b18b (BLK94RS)
The b20 has a larger bore than the b18b, and of course bigger pistons, and a different intake manifold, that is all I can think of as far as major difference's.
Do not quote me but I THINK, the crank's are the same.
Old Dec 3, 2001 | 06:15 PM
rainforest's Avatar
Default Re: B20 crank in b18b (hybridrex)
same 89mm crank so no difference. same 137mm rods also.
Old Dec 3, 2001 | 07:04 PM
InfamousRS's Avatar
Default Re: B20 crank in b18b (rainforest)
if it is the same crank and same rods, is it the pistons that give it that extra .20 liters of displacement? I was always under the impression that the b20 had a longer stroke? What bore does the b20 have?
Old Dec 3, 2001 | 07:19 PM
1.8EG-T's Avatar
I think it is 84mm. It is basically a b18a/b block bored way out stock.
Old Dec 3, 2001 | 07:37 PM
InfamousRS's Avatar
Would it be safe boring My b18b block out that far when running any amount of boost? Somday if when I get motivated enough, I would like to have a b18 block bored out as far as possible with Golden Eagle godzilla sleves. I want some major torque. How far out could I go with the new sleeves?
If I had the money I would consider a stroker kit, by crower with the crower crank, but I don't. What does a stroker kit take the stroke to, and what would the displacment be I you were running the largest bore possible with the golden eagle sleeves?
If you can't tell, I like torque, only if I had the money to make my dreams come true.
Old Dec 3, 2001 | 11:23 PM
nfn15037's Avatar
Just resleeve your LS block to 84.5 mm, that way you can get some nice forged pistons at the same time and run crazy boost
Old Dec 3, 2001 | 11:41 PM
InfamousRS's Avatar
Default Re: B20 crank in b18b (nfn15037)
Does anything need to be done to the head when taking the bore to 84.5? How much of a gane in torque would that be over stock?
What is the stock bore and stroke of a H22, is it possible to match that in a b series?
Old Dec 4, 2001 | 09:06 AM
dohc_Cx's Avatar
New User
well, i do know that u can have your head spotfaced to match your bore size but it's not necessary, it's just for more dipsplacement, i think..and it will have more torque over stock..try asking a machine shop to see how far u can bore before u encounter problems even with the blocked resleeved..i'm interested too..
Old Dec 4, 2001 | 01:12 PM
InfamousRS's Avatar
Default Re: B20 crank in b18b (rACEr_b_O_y_)
So, I would have golden eagle instal the sleves, and a local machine shop bore and hone it to 84.5? is it safe to go larger?
Old Dec 4, 2001 | 08:08 PM
nfn15037's Avatar
Golden eagle should be able to install 84.5 mm sleevs if you tell them thats what you want.
KustomCrx
Oct 22, 2004 10:05 AM
cyrock
Aug 5, 2004 06:26 PM
Hybrid
Dec 5, 2003 04:13 AM
dohc_Cx
Dec 17, 2001 08:05 PM
