colder spark plugs
Old Aug 23, 2004 | 04:16 PM
wizzards581's Avatar
Default colder, spark plugs...
is it good to use this type of setup??
i jus read on the timing belt cover and it said to use short tip type of spark plug. i have been using ones that they gave me for b18c's and i dont know if its short or long type.
which do they normally give?
Modified by wizzards581 at 3:30 AM 8/30/2004
Old Aug 23, 2004 | 04:39 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: colder spark plugs (wizzards581)
NGK BKR6E-11 for stock, or BKR7E-11 for a colder plug.
Old Aug 25, 2004 | 04:34 PM
Default Re: colder spark plugs (LSVTEC 91 Civic)
why run a colder plug? is it better for all motor?
Old Aug 25, 2004 | 06:03 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizzards581 &raquo;</TD></TR><TR><TD CLASS="quote">why run a colder plug? is it better for all motor?</TD></TR></TABLE>
If you're running high compression, yes.
Old Aug 27, 2004 | 09:51 PM
so it would not do anything if i ran colder plugs compare to regular plugs?
Old Aug 28, 2004 | 03:07 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizzards581 &raquo;</TD></TR><TR><TD CLASS="quote">so it would not do anything if i ran colder plugs compare to regular plugs?</TD></TR></TABLE>
No. Colder plugs retain less heat and will slightly reduce an engine's tendency to detonate.
Old Aug 28, 2004 | 11:44 AM
97mini-me's Avatar
Default Re: colder spark plugs (b19coupe)
I have the jdm itr engine. I know it has slightly higher compression than the US one, but can I use the US plugs? Suggestions?
-Brian
Old Aug 29, 2004 | 02:00 PM
Default Re: colder spark plugs (97mini-me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97mini-me &raquo;</TD></TR><TR><TD CLASS="quote">I have the jdm itr engine. I know it has slightly higher compression than the US one, but can I use the US plugs? Suggestions?
-Brian</TD></TR></TABLE>
yes... thats what i mean.i have the jdm GSR which is higher compression then the US. will the colder plugs make gain of hp?
Old Aug 29, 2004 | 02:13 PM
Banned
Colder plugs don't retain heat, they are best suited for high compression engines because they prevent detonation. Run a BKR7E-11, $1.89 from NAPA, good plug.
Old Aug 29, 2004 | 04:45 PM
zCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">
If you're running high compression, yes.</TD></TR></TABLE>
what would be considered high c/r?? 12.5/1 ?? Stock plugs or colder??
Old Aug 29, 2004 | 06:30 PM
Default Re: colder spark plugs (zCivic)
i guess i will buy colder plugs next time.
how about NGK G-Power Platinum, Laser Platinum, etc. other higher sparks.?
Old Aug 30, 2004 | 08:25 AM
Proglow3's Avatar
I like NGK's Irirdium plugs. check them out... http://www.ngksparkplugs.com/iridium
Old Aug 30, 2004 | 05:18 PM
Default Re: colder spark plugs (Proglow3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Proglow3 &raquo;</TD></TR><TR><TD CLASS="quote">I like NGK's Irirdium plugs. check them out... http://www.ngksparkplugs.com/iridium
higher plugs are alwase better power... but get colder with higher comp motors rite?
Old Sep 3, 2004 | 08:10 AM
ghettochild's Avatar
i have a lsvtec turbo with 11.5 comp and i used NGK colder plugs and it helped out a **** load with detonation.
buffgsr
Mar 25, 2008 04:56 PM
kevaccord
May 10, 2007 01:29 PM
VSBB6
22
May 16, 2005 06:28 AM
Trailz-EX
Jan 23, 2005 01:33 PM
gassinit
Dec 12, 2003 05:48 PM
