H22 Injectors
I haave a set of Obd-1 H22 injectors going on a built LS in an EG! Do I need a new resistor box or will mine work fine! If so what resistor boxes can I use or what ohm resistors can I use to make it work!
yea you have to use the resistor box, you can use any resistor box from any old honda or acura. but if you are going to use the resistor from radioshack i think its 10 Ohm 10 watt reistors and put them in series.
nokturnal_munkeeboy
14
Apr 16, 2007 03:43 PM
