91crx zc swap help
what do i need to do a zc swap for my 91 crx i know its a jdm motor but would the wireing be weird plz tell i really want to do this swap and b4 i buy the motor i want to know
If your CRX is an Si, or if you are running MPFI, the only thing different is the distributor plugs. the USDM SOHC uses one 7 wire round plug, and the JDM DOHC uses one 5 wire square plug, and the other two wires go to the CAS on the exhaust cam. Here is a picture of where to put what wire on what plug
If you are running DPFI, then you'll need to convert to MPFI, and then do all that.
Turbodismantler
Nov 2, 2004 07:52 AM
99sonicbluegsr
Sep 16, 2004 07:43 AM
jdmhondacrx
Mar 16, 2003 11:28 PM
