Hood Clearence
Old Aug 23, 2004 | 01:48 PM
crxkane's Avatar
Default Hood Clearence
I currently have a lsvtec in a 90 crx si with a place racing mount kit, i had a B16 in there befor and had no problems with the hood shutting. With the new set up I can not get the hood to shut fully. What can i do to about this. I have searched and Tbone said that he had to shimm his hood with the 1.8 bottom end, is there anything else i may be albe to do???? any help will be greatly app.
Old Aug 23, 2004 | 02:04 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Hood Clearence (crxkane)
You could cut into the hood support skeleton where it hits the motor.
you could also get a different set of mounts.
Old Aug 23, 2004 | 02:12 PM
EL Vap133's Avatar
Default Re: Hood Clearence (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">You could cut into the hood support skeleton where it hits the motor.
you could also get a different set of mounts.</TD></TR></TABLE>
I believe Hasport is still in the works of making a mount kit to allow hood clearance.
Old Aug 23, 2004 | 02:30 PM
crxkane's Avatar
I am not trying to spend $400+ dollars to have the hood clear, that is just a little out of the question. So it looks as if cutting the hood or shimming is the only other options?
Old Aug 23, 2004 | 02:37 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxkane &raquo;</TD></TR><TR><TD CLASS="quote">I am not trying to spend $400+ dollars to have the hood clear, that is just a little out of the question. So it looks as if cutting the hood or shimming is the only other options?</TD></TR></TABLE>
Yes, unless you wanna spend money.
Old Aug 23, 2004 | 02:43 PM
crxkane's Avatar
Default Re: Hood Clearence (EL Vap133)
well that just about sux
Old Aug 23, 2004 | 04:33 PM
crxdx89's Avatar
just take a 4 in grinder to the hood skeleton, i did that and it took like 10 mins including stopping to get a drink. its quick, simple, and u also reduce weight lol. it should give u good clearance
Old Aug 23, 2004 | 04:36 PM
ls_vtec_crx's Avatar
cutting it would be best....thats what imma do
Old Aug 23, 2004 | 04:38 PM
i THINK that the ZC hood fits....correct me if im wrong....but thats on the expensive end
Old Aug 23, 2004 | 04:41 PM
ek_99_SiR's Avatar
Default Re: (ls_vtec_crx)
dont cut anything dont buy and new hood... put washers under the mount and problem solved
Old Aug 24, 2004 | 04:23 AM
crxkane's Avatar
Default Re: (1.6i-16zc)
you mean put the washers under the mount and shim the motor down????
Old Aug 24, 2004 | 05:06 AM
manson's Avatar
Default Re: (crxkane)
CUT IT!!!!
freedm
18
Jan 14, 2009 07:08 PM
JDM00SI
Nov 15, 2005 06:46 AM
CivicB18C1
56
Dec 15, 2004 12:14 PM
Jerod
Jul 9, 2004 03:17 PM
