Whats the Cheapest...Best...Adjustable Camber Kit?For a 3in Drop..
I have a 92 LS i want the cheapest,best adjustable camber kit..My car is dropped about 3in....I just want a camber kit for the front...
Where can i get it online?
Thanks Alot!!
Thanks Alot!!
Well my car is dropped 2.25 inches and i went with the comptech camber kit but really they are ingalls kits so go with the best , which are ingalls and comptech has the rubber bushing kits so you will have a quiet ride. however if you have bigger tires they might not be able to correct it to 0 degrees because your tires will rub. The guy at NTB got it the front to 1.1 degrees in the front whick is still compliant with factory specs but I have to rotate my tires every 3-4,000 miles so my tire wall won't wear unevenly i don't know about 3 inches what they will be able to do, you should put washers in the back to correct that camber because its probably about 1-2 degrees of negative camber in the back
E36 Guy
16
Apr 7, 2006 09:58 AM
