Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
D/S ITR running A3S04 in the rear
Old Aug 23, 2004 | 12:52 PM
bbqman's Avatar
Default D/S ITR running A3S04 in the rear
Has anyone experienced tire rubbing on the trailing arm with the new Hoosiers.
I ran A3S03 last year without spacers in the rear and there was no contact. I just renewed the rears last week and at the first event, they got real blue as they worn against the trailing arm.
I know I can run rear 5mm spacers to correct this, but my question is, how will this affect the cars tendancy to oversteer when provoked?
Already I was concerned that the car would not rotate with the new grippy Hoosiers and know that I discover that they are wider and may need a spacer, I am not sure what to expect.
Any comments?
Old Aug 23, 2004 | 12:59 PM
philstireservice's Avatar
Default Re: D/S ITR running A3S04 in the rear (bbqman)
You won't even know they are there.....
Old Aug 23, 2004 | 01:51 PM
innocenti's Avatar
Default Re: D/S ITR running A3S04 in the rear (Maxx44)
I have only had slight rubbing on the trailing arms with my 205 S04's. It was from a high speed transition. That is the only time I had rubbing on the rears. If you run on concrete you will want to invest in the spacers.
Dave
Old Aug 23, 2004 | 05:09 PM
bfitz's Avatar
I have some evidence of rubbing with 205 A3S04's and 5mm spacers. Get the spacers. As for getting the rear to rotate...I've finally figured that out. I gradually upped the rear pressures to 65 psi with little change. When that didn't work, I went down to 33, and the rear came alive.
Freshdot
16
Jan 7, 2015 10:03 AM
Franshow
Sep 10, 2013 11:13 PM
AccordSleeperZzZ
Apr 3, 2009 07:05 AM
Azcheron
Honda S2000
41
Mar 5, 2009 10:00 PM
subzero_SiR
Sep 8, 2003 09:17 PM
