Changed timing belt now no low end power?
Old Aug 23, 2004 | 12:25 PM
vtec69's Avatar
Default Changed timing belt now no low end power?
We just finished a timing belt change due to it breaking on my friends car
We changed the head and put all good valves in and now after its done there is almost no low end power?!?
Could this be due to the timing being off or is there other factors that could cause this?
thanks
-Brian
Old Aug 23, 2004 | 12:40 PM
dip-set's Avatar
Default Re: Changed timing belt now no low end power? (vtec69)
timing may be off,valve lash specs may be too tight/loose..
Old Aug 23, 2004 | 12:42 PM
vtec69's Avatar
Default Re: Changed timing belt now no low end power? (b18b-se)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b-se &raquo;</TD></TR><TR><TD CLASS="quote">timing may be off,valve lash specs may be too tight/loose..</TD></TR></TABLE>
well when we first started it, it started right up but the valves were ticking a lot so we did a valve adjustment and now everything is right in spec.
Old Aug 23, 2004 | 12:58 PM
dip-set's Avatar
its not right on spec if u did the adjustment while the motor was hot,it has to be completely cooled for an accurate valve adjustment..
Old Aug 23, 2004 | 01:04 PM
iwannaboostmyteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b-se &raquo;</TD></TR><TR><TD CLASS="quote">its not right on spec is u did the adjustment while the motor was hot,it has to be completely cooled for an accurate valve adjustment..</TD></TR></TABLE>
Old Aug 23, 2004 | 01:09 PM
vtec69's Avatar
Default Re: Changed timing belt now no low end power? (iwannaboostmyteg)
well we didnt do it right away
we let the car cool off over night and did it in the mornig so i dont think thats the problem but thanks for the advice
Old Aug 23, 2004 | 01:37 PM
still I'd check them again you might have not tighten'd enough and they might have knocked loose again. also check your power steering pump and stuff because they are also known to come loose at times..
Old Aug 23, 2004 | 01:57 PM
VTECrazed's Avatar
Your timing is off. Something was not lined up when you put the new belt on.
Old Aug 23, 2004 | 02:37 PM
vtec69's Avatar
Default Re: Changed timing belt now no low end power? (VTECrazed)
well im getting a timing light hopefully tomorow so ill let you know how it goes
Old Aug 24, 2004 | 03:57 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 &raquo;</TD></TR><TR><TD CLASS="quote">well im getting a timing light hopefully tomorow so ill let you know how it goes</TD></TR></TABLE>NOOoooo.... It sounds like your cam timing is off. Check & fix that first, before you do spark timing.
Old Aug 24, 2004 | 06:21 AM
tnord's Avatar
Default Re: Changed timing belt now no low end power? (JimBlake)
if you're off a tooth on the timing belt the car will run, but it will run like crap. which may be the case here.
Old Aug 24, 2004 | 04:11 PM
vtec69's Avatar
Default Re: Changed timing belt now no low end power? (tnord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnord &raquo;</TD></TR><TR><TD CLASS="quote">if you're off a tooth on the timing belt the car will run, but it will run like crap. which may be the case here.</TD></TR></TABLE>
Ok cool didnt get a chance to do either today but hopefully tomorrow I'll check the cam timing and the spark timing
thanks for your help and ill let you know how it works out
Old Aug 24, 2004 | 07:44 PM
94b18c1's Avatar
ya its your timing
Old Aug 25, 2004 | 12:19 PM
vtec69's Avatar
Default Re: Changed timing belt now no low end power? (94b18c1)
still havent seen my friend since but Im defenitly going to make sure the timing belt is on properlly first then if it is then im gonna check the ignition timing cause right now he has it advanced all the way cause he didnt have a timing light and he said it ran the best like that
Thanks for the help so far
I'll keep everyone updated
-Brian
Old Aug 25, 2004 | 12:45 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
On my friend's H22 swap in his del Sol, the exhaust cam was off about a tooth, and the car had NO pickup at all. He fixed it last weekend and immediately it got ALOT faster.
thunderboy
Aug 21, 2008 05:05 PM
BUDtoker
20
Nov 6, 2007 10:25 AM
swindler86
14
Oct 25, 2005 09:38 PM
spyderracing
Aug 23, 2004 04:47 AM
E-Rok
Jun 19, 2003 10:04 AM
