CRX HF, Front Hub Swap..............
Old Aug 23, 2004 | 07:27 AM
CReXB18's Avatar
Default CRX HF, Front Hub Swap..............
I swapped the front hubs off of a 90 integra onto my 88 CRX hf. I just got my motor started and i drove it, But the brakes arent working properly. I have to pump them a few times for it to actually start to STOP, I bleeded the brakes and everything. Is there something I need to do to complete the conversion???? All i did was swap the hubs, I left the stock lines and cylinder and everything.
I also Have Slotted front rotors and Kevlar Brake Pads If that makes a diffference, PLEASE HELP!
Old Aug 23, 2004 | 08:28 AM
5litereater's Avatar
Default Re: CRX HF, Front Hub Swap.............. (CReXB18)
bleed them again. sometimes they wont fully bleed the first time.
Old Aug 23, 2004 | 12:42 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CReXB18 &raquo;</TD></TR><TR><TD CLASS="quote">I swapped the front hubs off of a 90 integra onto my 88 CRX hf. I just got my motor started and i drove it, But the brakes arent working properly. I have to pump them a few times for it to actually start to STOP, I bleeded the brakes and everything. Is there something I need to do to complete the conversion???? All i did was swap the hubs, I left the stock lines and cylinder and everything.
I also Have Slotted front rotors and Kevlar Brake Pads If that makes a diffference, PLEASE HELP!</TD></TR></TABLE>
I'm not following how a hub swap changed the performance of your brakes.
Old Aug 23, 2004 | 02:34 PM
RedSI93's Avatar
Default Re: CRX HF, Front Hub Swap.............. (travis)
He had to unhook the lines from the stock calipers..and attach them to the ones on the integra spindle. Dude U jsut need to keep bleedin...still got air in the line.
Good luck
Old Aug 23, 2004 | 04:53 PM
travis's Avatar
Default Re: CRX HF, Front Hub Swap.............. (89LScrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89LScrx &raquo;</TD></TR><TR><TD CLASS="quote">He had to unhook the lines from the stock calipers..and attach them to the ones on the integra spindle. Dude U jsut need to keep bleedin...still got air in the line.
Good luck </TD></TR></TABLE>
Well, if that's the reason, it's basically the same as replacing a caliper. I agree, bleed again.
Old Aug 23, 2004 | 05:08 PM
mar778c's Avatar
Community Builder
Community Influencer
I had the same problem. I had replaced the master cylinder and it didn't make a difference. Brake bleeding, etc no difference. My solution was to replace the proportioning valve with one from a 4dr 92-95 civic. The set-up is seems weird but it works way better than most with 4-wheel disc brakes.
91stocker
Suspension & Brakes
Jun 19, 2018 11:37 AM
rextec
Mar 21, 2007 10:35 AM
deerek101
Feb 7, 2006 09:01 PM
No
Aug 28, 2005 10:22 PM
ExplicitSpeed
Oct 5, 2004 06:48 PM
