MUGEN rear wing test-drive at Salzburg Ring
Old Aug 23, 2004 | 01:57 AM
austrian type-R's Avatar
Default MUGEN rear wing test-drive at Salzburg Ring
On friday I was the 7th time on the Salzburg Ring for an open track day. The long straight with a slightly left corner and going a little up hill, I hit 270kmh @ 8200rpm (mix'n match gear tranny) on the speedo. Last year with the oem wing the car feelt very light in the rear when I go off the throttle at that speed, kinda scary. This time the car feelt way more stable in this situation, like it should be. I have same tires and same alligment specs on the suspension to get a compare.
The Mugen wing is set at fully downforce
Old Aug 23, 2004 | 02:08 AM
uNF$@#!'s Avatar
Default Re: MUGEN rear wing test-drive at Salzburg Ring (austrian type-R)
uhm....
anytime you take a turn and throttle lift you are going to unsettle the car.
Old Aug 23, 2004 | 03:21 AM
.RJ's Avatar
.RJ
Default Re: MUGEN rear wing test-drive at Salzburg Ring (w@@t w@@t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w@@t w@@t &raquo;</TD></TR><TR><TD CLASS="quote">anytime you take a turn and throttle lift you are going to unsettle the car.</TD></TR></TABLE>
If you pop off the loud pedal, sure... if you do it smoothly it should not unsettle the car at all.
Old Aug 23, 2004 | 03:25 AM
uNF$@#!'s Avatar
Default Re: MUGEN rear wing test-drive at Salzburg Ring (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
If you pop off the loud pedal, sure... if you do it smoothly it should not unsettle the car at all.</TD></TR></TABLE>
you know how i drive. im a noob with a lead foot.
Old Aug 23, 2004 | 05:19 AM
swlabhot's Avatar
Wot, no pics this time !?!?
Old Aug 23, 2004 | 06:10 AM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by austrian type-R &raquo;</TD></TR><TR><TD CLASS="quote"> Last year with the oem wing the car feelt very light in the rear when I go off the throttle at that speed, kinda scary. This time the car feelt way more stable in this situation, like it should be.</TD></TR></TABLE>
As one would expect.
Old Aug 23, 2004 | 06:16 AM
Opie's Avatar
No Video?
&lt;--Starting to really like the idea of that wing...
Old Aug 23, 2004 | 06:18 AM
Bradstard's Avatar
I am glad that it is actually functional. I personally think it's pretty damn ugly.
Old Aug 23, 2004 | 06:44 AM
Justin Klemgold's Avatar
Default Re: MUGEN rear wing test-drive at Salzburg Ring (Fat Bradstard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">I am glad that it is actually functional. I personally think it's pretty damn ugly.</TD></TR></TABLE>
I agree...it would look good on the RSX, but the Mugen wing does not flow with the curves of the ITR IMO...the ITR is rounded, the Mugen wing is boxy...
Old Aug 23, 2004 | 07:26 AM
Big Phat R's Avatar
With the stock wing - I found my R to be really "squirrelly" under hard braking. This was greatly reduced with the Mugen wing.
Increasing the front spring rate significantly also helped (with nose dive)
Old Aug 23, 2004 | 08:01 AM
George Knighton's Avatar
H-T Order of Merit
You guys need to stop making me think about getting that $700 wing.
Old Aug 23, 2004 | 08:04 AM
ZygSpeed's Avatar
Default Re: (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">You guys need to stop making me think about getting that $700 wing. </TD></TR></TABLE>
And don't forget to get a roadracegear front splitter, too!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Klemgold &raquo;</TD></TR><TR><TD CLASS="quote">...the ITR is rounded, the Mugen wing is boxy... </TD></TR></TABLE>
There are reasons why it's boxy, and I think it adds "character" to the car.
.RJ's Avatar
.RJ
Default Re: (zygspeed)
And he'll still get r0lled
Old Aug 23, 2004 | 08:11 AM
H-T Order of Merit
Default Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">And he'll still get r0lled </TD></TR></TABLE>
LOL.... If you mean by your left-foot-braking, tail swinging, bad instructor self...I'm sure!
Old Aug 23, 2004 | 08:14 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
LOL.... If you mean by your left-foot-braking, tail swinging, bad instructor self...I'm sure!</TD></TR></TABLE>
lol...as far as I know, RJ's car won't go through T9 sideways in 4th gear
Old Aug 23, 2004 | 08:18 AM
.RJ's Avatar
.RJ
Default Re: (Ross R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross R &raquo;</TD></TR><TR><TD CLASS="quote">RJ's car won't go through T9 sideways in 4th gear </TD></TR></TABLE>
No
I need to do something... maybe go through T6 w/o braking to carry enough speed into T9. And then there's that whole T10 mess. Maybe w/ R-tires the situation will resolve itself
Old Aug 23, 2004 | 08:21 AM
Ross's Avatar
25 Year Member
Community Builder
Default Re: (.RJ)
Maybe w/ R-tires the situation will resolve itself </TD></TR></TABLE>
Or 200whp.
Old Aug 23, 2004 | 08:41 AM
H-T Order of Merit
Default Re: (.RJ)
I need to do something... maybe go through T6 w/o braking to carry enough speed into T9. And then there's that whole T10 mess. Maybe w/ R-tires the situation will resolve itself </TD></TR></TABLE>
You know that's not true.
I've told you what to do, dammit.
I'm telling you...bounce off that gater on the right, turn left, then be in fourth before the next right, and FLOOR it up the hill....they <u>will</u> have to point you by!
Old Aug 23, 2004 | 08:53 AM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by austrian type-R &raquo;</TD></TR><TR><TD CLASS="quote">... I hit 270kmh @ 8200rpm (mix'n match gear tranny) on the speedo. </TD></TR></TABLE>
For the rest of us on the English system, thats around 167 mph.
Old Aug 23, 2004 | 09:11 AM
uNF$@#!'s Avatar
in confused...you guys have driven on the salzburg ring?
Old Aug 23, 2004 | 09:34 AM
Ross's Avatar
25 Year Member
Community Builder
Default Re: (w@@t w@@t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w@@t w@@t &raquo;</TD></TR><TR><TD CLASS="quote">in confused...you guys have driven on the salzburg ring? </TD></TR></TABLE>
Talking about Summit now, Captain Lemonparty.
Old Aug 23, 2004 | 09:58 AM
Lucky-R's Avatar
once again to all the naysayers...i used to be in your group. but, you have to see the Mugen Wing in person strapped onto an R before you knock it . its really not as unproportioned to the car's bodylines like you think, atleast to me it isnt. i was a convinced how ugly it was until i actually came face to face with one in person. pure adrenaline
Old Aug 23, 2004 | 10:47 AM
geometro's Avatar
Another satisfied customer.
The thing may be ugly, but it works, damn it.
In my post never washed in 2 years car you can "see" what it's doing.
If you want a wing that flat out works and find beauty in functionality, like others of users of the wing have said: get it.
Accept no substitute.
George
Old Aug 23, 2004 | 10:52 AM
Ross's Avatar
25 Year Member
Community Builder
Default Re: MUGEN rear wing test-drive at Salzburg Ring (geometro)
Are you the instructor in VA with the black ITR?
Old Aug 23, 2004 | 11:55 AM
uNF$@#!'s Avatar
Default Re: MUGEN rear wing test-drive at Salzburg Ring (Ross R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross R &raquo;</TD></TR><TR><TD CLASS="quote">Are you the instructor in VA with the black ITR?</TD></TR></TABLE>
do you have a painted aluminum wing or unpainted aluminum piece?
