help with idle
Old Aug 22, 2004 | 11:32 PM
b18cEF9's Avatar
Default help with idle
ok so my car overheated, i lost a little fluid and i replaced the lost fluid, bled the lines and everything but now my car idles at 1500rmp and i dunno why... any help please
Old Aug 22, 2004 | 11:49 PM
gsrmike's Avatar
Default Re: help with idle (b18cEF9)
Try checking your IACV (Idle Air Control Valve). Not sure about your particle engine but on my GSR it's bolted on the back of the intake manifold. When you pull it off check the two passages on the back. Check for corrosion. Coolant passes through them. Clean if needed. Here's a pic:
It also may be the FITV (Fast Idle Thermo Valve). This controls idle when the car is cold (raises idle when cold to help warm engine up). Heres a good link on it since i've never replaced/checked it. https://honda-tech.com/zerothread?id=699787
Does your car surge or does it just sit at a steady 1500rpm? Does it only do this when cold, warm, or all the time?
Old Aug 23, 2004 | 01:00 PM
b18cEF9's Avatar
Default Re: help with idle (gsrmike)
well it starts really hard and it idles at 2500 untill it get warmed up and thn it idles at 1500 rpm, i got a gsr so is it located under the IM or behind it?
Old Aug 23, 2004 | 01:23 PM
SuperJay's Avatar
I tightened my FITV and it made the car idle like **** when it's cold. The thing would stall out and miss. It's set from factory to give you a set cold idle, and shouldn't be messed with. I seen in another post that it should be tight, and it shouldn't. It's set from factory. DO NOT tighten the FITV, clean, it, but do not tighten it. If you did tighten it and find that you have a shitty cold idle, unscrew it a couple turns, maybe more. Might have to try this a couple times to get it right. If you haven't touched it and have a shitty warm idle, then this is definitely not your problem.
Modified by SuperJay at 2:42 PM 8/23/2004
Old Aug 23, 2004 | 01:58 PM
4DRmafia's Avatar
check the iacv because this is the most common plm and take it off from the behide the intake manifold then clean it out with carb cleaner or brake cleaner
Old Aug 23, 2004 | 02:23 PM
RedSI93's Avatar
Default Re: (SuperJay)
But what causes it to stop operating properly?? Do they jsut get dirty....or worn out??
Old Aug 23, 2004 | 02:26 PM
4DRmafia's Avatar
they just get dirty
Old Aug 23, 2004 | 02:34 PM
APEX CRX's Avatar
Default Re: (89LScrx)
dirty/cruddy.
Old Aug 23, 2004 | 02:36 PM
SuperJay's Avatar
Sometimes, they leak. Sometiimes the seals go. Sometimes dirt gets inside. Just normal wear and tear. But as far as the screw inside, they are set to give you a "set" cold idle. The more you screw in, the lower your cold idle. The more screwed out, the higher your cold idle. If it is out too far, it may effect operating temp idle because some air may be leaking. But, by no means should it be screwed all the way in. Unless you like stalling/missing/sputtering while cold. You could screw it all the way in, but you'll have to sit there with your foot on the gas idleing it to warm up the motor till the EACV/IACV can take over Idle control.
Old Aug 23, 2004 | 04:10 PM
Boosted Chemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cEF9 &raquo;</TD></TR><TR><TD CLASS="quote">ok so my car overheated, i lost a little fluid and i replaced the lost fluid, bled the lines and everything but now my car idles at 1500rmp and i dunno why... any help please</TD></TR></TABLE>
well i had a similar problem, bleed the sytem (make sure the thermo is open) and now it idles fine, some times some air in the line causes fluid not to get everywhere it needs to go
Old Aug 24, 2004 | 01:00 AM
b18cEF9's Avatar
Default Re: help with idle (Mad Chemist)
well i bled the the cooliong system, idles the same and the the mtor gets warm so i think the thermo is opening but it sees like the motor take a little bit longer to warm up..... maybe the antifreeze water mixture is incorrect but i think im gunna go take the fitv off and see if it needs cleaning, any other info will be helpful
Old Aug 24, 2004 | 06:05 AM
spaceman's Avatar
good luck dood,keep us posted
Old Aug 24, 2004 | 10:58 AM
b18cEF9's Avatar
Default Re: help with idle (spaceman)
well last night at 3 i started workin on my car to try to get the FITV off, well that damn rear mount didnt want anything to do with it, i tried lifting the motor with a jack and it didnt work, so basically i cant take the ****** fitv off, perty gay
Old Aug 24, 2004 | 12:18 PM
SuperJay's Avatar
ummmm, Not too sure about you, but I didn't need to pull my motor to get the FITV off.
Old Aug 25, 2004 | 01:26 AM
b18cEF9's Avatar
well my rear mount is in the way to get my FITV off, b18c manifold makes no room for me, but i think i found the problem, im not sure if th thermo is opening up all the way, motor temp stays cold so it idles high, but the radiator seems like its normal temp..... any info would be very helpful......oh and woud it be easy to just unscrew the block off plate at the end of the FITV and screw that white thing in or just take the hole thing off? please help m im getting frustrated
Old Aug 25, 2004 | 10:12 AM
b18cEF9's Avatar
Default Re: (b18cEF9)
ick
Sep 11, 2005 10:46 PM
speedaccordinly24
May 17, 2003 04:40 PM
Eurasia00
Apr 22, 2002 11:37 AM
