compression test results - good to go on turbo
Old Aug 22, 2004 | 07:17 PM
Scean's Avatar
Default compression test results - good to go on turbo
compression test on d15b7 - #'s were right at 160 highest was 170 lowest was probobally, 157 so im in good shape there, im going to be putting on a 97gst t25 turbocharger and running only at 5.5psi because i know this motor cant handle much, ill be using uberdata with 450cc dsm injectors, is my set up safe? fuel management good enough and compression #'s good enough? thanks for your info/opinions
motor has about 95000 miles on it by the way
Old Aug 23, 2004 | 04:16 AM
Scean's Avatar
Default Re: compression test results - good to go on turbo (blackcivic95)
30 looks not a single response?
im just about positive im straight just needed like a thumbs up from a couple ppl to reasure myself
mikeivb
Nov 11, 2009 11:13 AM
b18bme
Nov 26, 2006 07:40 PM
InLimbo87
Jun 22, 2004 07:54 PM
InLimbo87
Jun 19, 2004 01:50 PM
Charlie Moua
Dec 30, 2002 07:16 PM
