Does any one know what the noise when i reserve
Old Aug 22, 2004 | 06:45 PM
B18C-VTI_R's Avatar
Default Does any one know what the noise when i reserve
when im reversing in my gsr. the gearbox makes a horrible noise, sounds like a grinding noise. tell me someone
Old Aug 22, 2004 | 07:11 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Does any one know what the noise when i reserve (B18C-VTI_R)
All manual transmission cars w/ non-synchronized reverse gears make a "whirrrr whirrrr whirrrrrr" sound when you back up.... probably not the best way to type out a description of the sound
Old Aug 22, 2004 | 07:13 PM
RaYnE's Avatar
lol..hey..you do whatcha gotta do..made sense to me!
Old Aug 22, 2004 | 07:54 PM
nonturbo's Avatar
check the oil level.....
may be oil too old
Old Aug 24, 2004 | 06:32 PM
foolintherain617's Avatar
Default Re: Does any one know what the noise when i reserve (nonturbo)
Most tegs go into reverse hard too in order to prevent going from 5th directly to reverse and f-ing up your car. All of the teg ive driven do this. Maybe you didnt have it in all the way. I know ive ground mine once or twice being absent minded about it.
Old Aug 24, 2004 | 07:34 PM
xteg95's Avatar
Default Re: Does any one know what the noise when i reserve (foolintherain617)
mine does the same thing if you put it into reverse if your rolling at all...sounds fine when your at a full stop. kinda sounds like a crunching noise riight?
Old Aug 24, 2004 | 07:49 PM
3.504's Avatar
Default Re: Does any one know what the noise when i reserve (xteg01)
it clashes when first going into reverse (not engaging clutch, but actually pushing the selector into gear) because you're moving spur cut gear into spur cut gear. all other gears are sliding syncronizer ring accross clutching teeth that are speed matched by a blocking ring.
if you are rolling in gear in reverse w/ the clutch engaged and you are hearing grinding noises, some of the teeth on the idler and other reverse gears (can't think of it off the top of my head, i'm caffein buzzin like crazy right now) have chipped teeth.
ADL
Honda Civic (2016 - Current)
Jan 17, 2019 12:31 AM
saturn78
Apr 2, 2007 03:11 PM
2000GSR
Nov 28, 2004 10:01 AM
jeffb16
Oct 6, 2004 05:00 AM
