S2000 Antenna in a G2 Integra..
Old Aug 22, 2004 | 06:40 PM
RaYnE's Avatar
Default S2000 Antenna in a G2 Integra..
I bought my 91 Integra GS about a month ago..with a busted antenna..
it looked horrible and flopped around..
so i decided to try an s2k antenna. i tried researching it, but only for stuff on G3s.. but i went ahead and ordered the parts from honda.
heres the parts (antenna, pad, nut, insulator)
took out the old antenna, and motor assembly
after i installed it
getting the antenna to hold on was the hardest part. the pad and insulator actually fit in very nice and snug. i took the nut and from underneath slid it in with some adhesive to keep it in nice.
to get the antenna to work, i took the wire from the radio which has a female type end to it. it attatches to the motor assembly and antenna. but since the motor is no more, i cut it with a hack saw in a cross pattern and peeled back the metal. i then found a nut that screwed into the antenna and held it to the wire by wrapping the now spread out piece onto the nut like a claw. i then screwed on the antenna itself into the nut and put a bit of tape for some more strength, pulled the wire back through the hole and it now sits fine.
this mini project cost me about $65 canadian
im still trying to figure a way to keep the antenna on better. i was thinking some kinda super glue. any ideas?
*edit* you can see the wire i cut up in the second pic above the hole. *edit*
Modified by RaYnE at 11:07 PM 8/22/2004
Modified by RaYnE at 11:08 PM 8/22/2004
Old Aug 22, 2004 | 06:55 PM
Hcivic88's Avatar
Default Re: S2000 Antenna in a G2 Integra.. (RaYnE)
great write up
could have used some before pics... but other than that
good to see someone else from my area that knows what they're doing
Old Aug 22, 2004 | 06:56 PM
be.twenty's Avatar
Looks good, I don't know if I'd glue it though. I'd rather fasten it from the inside of the body panel...
Old Aug 22, 2004 | 07:00 PM
psychotic_z's Avatar
Default Re: (shogun-dc2)
I just did the same project in my DA just a few weeks ago...but I used the Shark Antenna 2 kit from Locash ($30) and it fit in with no problems. Reception isn't bad either, better than no antenna, but it looks great. I wish I had some pics though
Old Aug 22, 2004 | 07:05 PM
-DKap-'s Avatar
Default Re: (psychotic_z)
STEP AWAY FROM THE GLUE!!!
and the duct tape ... 2 things that r NOT suppose to be on cars ... super glue can be used to a min.
Old Aug 22, 2004 | 07:06 PM
RaYnE's Avatar
thx for the replies guys..
psychotic, did your kit wire up as well?
and i still get the same reception as before as well..
Old Aug 22, 2004 | 07:09 PM
RaYnE's Avatar
actually..it was electrical tape..and you cant even see it, and the adhesive i used was actually a silicone.
Old Aug 23, 2004 | 02:02 PM
RaYnE's Avatar
anyone else with some ideas to fasten the antenna to the base?
the antenna only pulls out like half an inch if i pull it..but id like to get it to not move at all..
Old Aug 23, 2004 | 02:07 PM
JDMThoughts's Avatar
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
Default Re: (RaYnE)
Silicone might work, I am not sure how well it's conductivity but it might work and make it seal better.
Honda Hick's Avatar
I would suggest emblem glue. You can get it from auto stores for a few bucks. I used some on my wheel trim ('91 tegs have wheel trim) and it holds on really, really good. If you are looking for something that's not so permenant you could use some good quality clear silicon. It won't hold as well as the emblem glue but it cleans up easy.
Old Aug 23, 2004 | 02:38 PM
RaYnE's Avatar
ive tried silicone, but it doesnt seem to like to stick to the plastic and rubber.
ill check out for some emblem glue. if i come across it, ill give it a try, thanks
Old Aug 23, 2004 | 03:27 PM
Default Re: (RaYnE)
The wiring for mine was really simple... The kit included a wire attached to the antenna, the same male fitting that slides right into our original female fitting on the harness, as well as a power wire for an antenna booster if you choose. It was a pretty sick kit. Mounting it was a little different than yours, it sounds like...
Old Aug 23, 2004 | 03:51 PM
integraXTC's Avatar
do you have a pic like the 3rd one but from further away? Maybe the whole side of the car but focusing more on the antenna?
Old Aug 23, 2004 | 04:48 PM
ben_eg6's Avatar
Default Re: (RaYnE)
for real! it looks real good
Old Aug 23, 2004 | 04:53 PM
xiLLtegRax's Avatar
Default Re: (T_aznboy)
nice
Old Aug 23, 2004 | 05:24 PM
Wraith_G2IC's Avatar
Default Re: (xiLLtegRax)
If you go to http://www.g2ic.com just join up and search away. There are several articles on it. I never did it to mine when I was thinking of mounting on the roof since the reception is not as good as the orig. Also, the antena is designed to be used with a type of reciever amp under it. If you look inside a s2k there is a box under the antena that gives it the quality reception. I think it was an extra $60 or more for that part.
Also, FYI there was a guy on there that had some type of mount adapter to give it a more secure/better angle.
Old Aug 23, 2004 | 05:55 PM
RaYnE's Avatar
Default Re: (Wraith_G2IC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chitwn91rs &raquo;</TD></TR><TR><TD CLASS="quote">do you have a pic like the 3rd one but from further away? Maybe the whole side of the car but focusing more on the antenna?</TD></TR></TABLE>
no sorry i dont, i dont have a camera myself, but i can try to get you one..but trust me..its worth it, it looks sweet..get the kit, or DIY like i did..either way it works
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wraith_G2IC &raquo;</TD></TR><TR><TD CLASS="quote"> Also, the antena is designed to be used with a type of reciever amp under it. If you look inside a s2k there is a box under the antena that gives it the quality reception. I think it was an extra $60 or more for that part.
yeah, i know what your talking about, the piece was like almost $100 bucks more..
Old Aug 24, 2004 | 07:57 PM
integraXTC's Avatar
I'm still debaiting it, could you try to get me a pick please?
1SLaMMeDC2
Aug 8, 2007 04:32 PM
numotive
Jan 11, 2006 02:00 PM
krnsamiam
Jul 10, 2005 08:09 PM
SteelCityKid
Audio / Security / Video
12
Dec 16, 2002 11:52 AM
mercforty4
Mar 12, 2002 05:06 AM
