LBJ replacement
Old Aug 22, 2004 | 05:05 PM
kshymkiw83's Avatar
Default LBJ replacement
Does anyone have the Helms Manual page in Adobe format for the removal and replacement of the LBJ's? I can get it out of the spindle, but i am not sure about some of the seals with this thing. Any help would be appreciated.
Old Aug 22, 2004 | 06:58 PM
90dxhatch's Avatar
Default Re: LBJ replacement (kshymkiw83)
there is a c clip on it, remove that and the seal (like a metal ring that the axle buts up against) remove that, hit the old balljont out with a hammer and, then instal is the same backwards, good luck with that ring cause it sucks to get on well atleat for me it did.
-joe
Old Aug 23, 2004 | 02:08 PM
kshymkiw83's Avatar
Default Re: LBJ replacement (90dxhatch)
well i gto a pickle fork so i shoudl just be able to pry the LBJ up. But i was wandering if i have to have a press to get the new one seated right. Or if i can just hit it with a sledge to get it in.
Old Aug 23, 2004 | 02:12 PM
4drEF's Avatar
Keyboard Humorist
Hitting it on the head will damage the upper portion of it. It will cave in and might cause problems.
I pressed mine in with a table vice and a large socket. Get a large socket that is about the same diameter as the LBJ. Put it on top of the LBJ and load it into the vice. Tighten it down and it should press right in! Make sure you have another large socket on the other side so the LBJ threads have clearance to press in without running into the vice.
Old Aug 23, 2004 | 02:45 PM
92integra_gs's Avatar
use a pickle fork and hammer.....
http://www.binghamtonlife.com/...t.htm
say thank you
Old Aug 24, 2004 | 01:32 PM
kshymkiw83's Avatar
Default Re: (92integra_gs)
grassy ***
Old Aug 28, 2004 | 12:02 PM
kshymkiw83's Avatar
Default Re: (kshymkiw83)
well thanks for the help guys i got my LBJ replaced. It took about 2-3 hours as i had no vice or anything. I found the easiest way was to remove the whole arm, and take it off the car completely. This gives you a better angle to knock out the old LBJ and put the new one in.
Removal of the LBJ was easy after i got the clamp off.
replacment was easy too. I didn't ahve a vice so i took some motor oil and lubded up the new LBJ and the old arm. I pushed it in as far as i can by hand, and then took a socket and a 5lb rubber mallet and tapped it in the rest of the way. This worked like a charm. Now i can roll my car again, and get my LS/Vtec in
nexium7
Aug 23, 2012 04:19 PM
Richard Casto
May 7, 2006 08:15 AM
dwtyper
Dec 30, 2002 07:24 PM
GSpeedR
Jul 1, 2002 06:15 AM
serious
Jun 8, 2002 11:23 AM
