NEED HELP PLZ LOOK
Old Aug 22, 2004 | 04:51 PM
Status Sean's Avatar
Default NEED HELP PLZ LOOK
im rebuilding my gsr block and i came across a problem ! when i disassembled my rods 2 of the caps i think where on backwards ? heres my problem i am tryin to figure out which way the rod caps should be facing ? somone plz help me out i am in desperate need of help thanks
Old Aug 22, 2004 | 06:05 PM
Default Re: NEED HELP PLZ LOOK (rw92civic)
someone help
Old Aug 22, 2004 | 06:07 PM
G1 TEGGY's Avatar
i really could've sworn there wasn't a backwards or forwards for rod caps, i could be wrong though... why do you think they're on backwards?
Old Aug 22, 2004 | 09:06 PM
Default Re: NEED HELP PLZ LOOK (G1_TEGGY)
when i look at my caps 2 of them say p72 one way and the others say p72 the other way ? its quite confusing to me i dunno if all the caps should say p72 one way or the other thats what im tryin to figure out ? i think the person at the machine shop put the pistons in backwards ???
Old Aug 23, 2004 | 02:19 AM
G1 TEGGY's Avatar
you can't install pistons backwards man, it doesn't matter either way, the P72 is just to match the parts
Old Aug 23, 2004 | 02:29 AM
3.504's Avatar
you can install pistons backwards, they're marked w/ dots which way to face (dots toward intake). the rod caps just need to be aligned w/ the rod so the bearing recess is in the same location. facing either direction is ok, just make sure its facing the same direction it was when you pulled the rod out. you should always mark anything when pulling it out of a motor and always put it back in its spot.
Old Aug 23, 2004 | 12:56 PM
G1 TEGGY's Avatar
Default Re: NEED HELP PLZ LOOK (3.504)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 &raquo;</TD></TR><TR><TD CLASS="quote">you can install pistons backwards, they're marked w/ dots which way to face (dots toward intake). the rod caps just need to be aligned w/ the rod so the bearing recess is in the same location. facing either direction is ok, just make sure its facing the same direction it was when you pulled the rod out. you should always mark anything when pulling it out of a motor and always put it back in its spot.</TD></TR></TABLE>
come to think of it i did punch my caps to match up.. i still don't understand the pistons though, help me out here 3.504, what kind of difference would be made if they were backwards?
Old Aug 23, 2004 | 01:15 PM
yea on two caps my recess arent matching and if i turned them and intalled everything i wouldnt throw a bearing or do any worse damage ! thats what im tryin to figure out ! so it doesnt matter if all the rod caps dont say p72 in one direction ? everything was marked when i took everything apart so i knew where they went !
Old Aug 23, 2004 | 01:37 PM
Octoman's Avatar
As long as you put it back together the way it came apart you should be ok. All the manuals I read say to always do that.
MEn'MYEK
Apr 23, 2012 12:23 AM
C Hustle
Feb 17, 2010 06:21 PM
xxmikexx206
Feb 24, 2007 10:03 PM
YINGY
Nov 18, 2005 01:27 PM
