D-series ninja needs help
Old Aug 22, 2004 | 03:04 PM
1tyme's Avatar
Default D-series ninja needs help
i got a d16z6 boosting 10psi on a greddy kit with intercooler. the car overheated radiator cracked and white smoke started to come out of the breather on the head. I thought the somehting was wrong with the top half so i got a new gude head with turbo cam and a new head gasket. i also got a new metal radiator and changed all fluids. i finally put it all together last night and the same thing happens white smoke out of the breather and the car won't idle. is something wrong with the bottom of the block anyone come across this problem?
Old Aug 22, 2004 | 03:21 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: D-series ninja needs help (1tyme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1tyme &raquo;</TD></TR><TR><TD CLASS="quote">i got a d16z6 boosting 10psi on a greddy kit with intercooler. the car overheated radiator cracked and white smoke started to come out of the breather on the head. I thought the somehting was wrong with the top half so i got a new gude head with turbo cam and a new head gasket. i also got a new metal radiator and changed all fluids. i finally put it all together last night and the same thing happens white smoke out of the breather and the car won't idle. is something wrong with the bottom of the block anyone come across this problem?</TD></TR></TABLE>
Sorry bro, but I think your ringlands are toast.
Old Aug 22, 2004 | 03:29 PM
1boostedcivic's Avatar
Default Re: D-series ninja needs help (boostincoupe)
radiator is no good, go to napa and get del sol dual core for 100 plus shipping
Old Aug 22, 2004 | 03:33 PM
1tyme's Avatar
are my ringlands my piston rings?
oh and i already got a new radiator
should i just get a new block or just change my piston rings?
thanks
Old Aug 22, 2004 | 04:02 PM
usually with burnt ringlands u have black smoke as well. my advice to u, is turbo rebuild if u can, cause if ur radiator is good then u gotta rip open the the block anyway
Old Aug 22, 2004 | 04:03 PM
Default Re: D-series ninja needs help (1zexxedcivic)
if u can do the work your self just swap in some new pistons, byut then again u minus well throw some scat rods in there for 280 shipped
CRuby
33
Nov 20, 2014 11:07 AM
92silude
Dec 8, 2004 09:33 AM
speed_racer012
Apr 26, 2003 07:23 PM
