Timing belt noise
Old Aug 22, 2004 | 02:15 PM
EsQueue's Avatar
Default Timing belt tension noise
Reciently my h22a's auto tensioner went out. Which caused it to make a loud noise when I let off the gas anything higher than 3.5k and it will stop at around 2k. I got the auto tensioner replaced with a manual tensioner and the noise was completely gone till I drove it on the freeway. The noise is much more quieter but it is still there.
I adjusted the tension on the manual tensioner by:
1) removing the valve cover
2) setting the engine at TDC
3) loosening and tightining the adjuster nut
4) turning the crankshaft 3 teeth counter-clockwise
5) loosening and tightining the adjuster nut.
After doing this I still notice the sound.
I've already adjusted it 4 times and during some of those times, it will go away for a few minutes and come right back. Is it that the manual tensioner doesent hold it's tension?
PLEASE, help a brother out.
Old Aug 22, 2004 | 03:33 PM
edd001's Avatar
Default Re: Timing belt tension noise (SeaQuake)
from what you say it sounds like the tensioner.
when you chaged it did you renew the cam belt, if not it may have streched a bit.
Old Aug 22, 2004 | 06:12 PM
EsQueue's Avatar
Default Re: Timing belt tension noise (edd001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edd001 &raquo;</TD></TR><TR><TD CLASS="quote">from what you say it sounds like the tensioner.
when you chaged it did you renew the cam belt, if not it may have streched a bit.</TD></TR></TABLE>
Sorry, I have don't know what the belt is located. The only belts replaced were the timing and the balancer belts.
Old Aug 22, 2004 | 06:23 PM
TxTuner
Guest
Posts: n/a
Cam belt=timing belt. After installation and tension is set, the belt may stretch some and require more tension to stop the noise
Old Aug 22, 2004 | 11:10 PM
EsQueue's Avatar
Default Re: Timing belt tension noise (TxTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TxTuner &raquo;</TD></TR><TR><TD CLASS="quote">Cam belt=timing belt. After installation and tension is set, the belt may stretch some and require more tension to stop the noise</TD></TR></TABLE>
I've done it 4 times already. It seems that it is starting to get worse.
99cbm
Dec 23, 2013 05:59 AM
micah_m
Jul 26, 2013 09:09 AM
MeathooK
Sep 12, 2008 08:54 PM
h22 vtec lude
Dec 24, 2007 05:19 PM
