Replaced axles, H22 swap, have vibration underacceration
Has anyone every experienced this before. They are 5sp accord axles w/abs and that is the correct application for the car. But only under acceleration there is a shudder throughout the whole car.
are the axles you replaced the old ones with refurbished or used? if so they could be bad, thats what happened to me. if not could be ur alignment, tire balance... blah blah
im having the same problem with my swap..i just finished the swap a couple of days ago but i cant go passed 15 mph because the car shakes ALOT...likei ts going to fall apart..how bad is yours...oh btw i got accord axles using prelude shafts ( rebuilt)
They are remanned axles.....one of the ABS rings (drivers side), is all chewed up and missing teeth..........I don't know if that is the problem or not, but it will be replaced soon.
i have always put accord axles for the model of accord the h22a is in, sometimes the remanufactured ones are bad and have to be replaced a few times though. the reason to not use prelude axles in teh accord is they are too long.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by conesmasher »</TD></TR><TR><TD CLASS="quote">I finally got this fixed, got rid of alot of vibration under acceleration.
The other axle was fucked and needed replaced. </TD></TR></TABLE>
i found out the bar the goes in the axle hub what about 3mm too big and would cause the axles to lock at certain positions..the ****** that rebuilt them figured it out and replace them..now i dont have any vibration...take your car back to who ever rebuilt the axles and have them check..i would tow the car if its not too far because you can **** up your wheel bearings..peace good luck
93, accelerate, accelerating, acceleration, accord, axle, axles, bad, car, h22, h22a, swap, vibrate, vibrating, vibration
