Opinions and or Alternatives to Hondata 3 step
Old Aug 22, 2004 | 12:35 PM
NiceDc2r's Avatar
Default Opinions and or Alternatives to Hondata 3 step
I am going to be getting the Hondata s200 system pretty soon...I am also debating whether or not to get the 3 step....It sounds like the 3 step would be pretty nice to have, especially the launch control...But, I am concerned how the launch control uses a fuel cut instead of ignition cut, and running a high compression motor (12.6:1) a fuel cut could be dangerous...I am also not to sure about the full throttle shift and daily driving, and now i am hearing about play in the clutch peddle with the micro switch...Please post your opinions and experience with the hondata three step and or the alternatives out there...Thanks in advance
Old Aug 22, 2004 | 01:02 PM
Rick Solis's Avatar
Default Re: Opinions and or Alternatives to Hondata 3 step (NiceDc2r)
I like the MSD ignition/rev control/2 step set up...
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NiceDc2r &raquo;</TD></TR><TR><TD CLASS="quote">I am going to be getting the Hondata s200 system pretty soon...I am also debating whether or not to get the 3 step....It sounds like the 3 step would be pretty nice to have, especially the launch control...But, I am concerned how the launch control uses a fuel cut instead of ignition cut, and running a high compression motor (12.6:1) a fuel cut could be dangerous...I am also not to sure about the full throttle shift and daily driving, and now i am hearing about play in the clutch peddle with the micro switch...Please post your opinions and experience with the hondata three step and or the alternatives out there...Thanks in advance</TD></TR></TABLE>
Hondata 3 Step Rev Limiter so far has been a semi-pain in the behind.
The launch control works fine. It holds the revs, and the launches are great. But as far as the full-throttle shift, the clutch switch is really sensitive. If you don't let out your foot off the clutch all the way, it'll sometimes limit your revs.
Example:
1st Gear, 3000RPM launch up until 8200RPM Redline (on a B16A Motor for Example)
Push Clutch In, Hondata brings revs down to 6500RPM.
Shift to 2nd Gear and Let Clutch Go, and your tires chirp, and lets say you're at 6200RPM in 2nd gear.
All of a sudden it accelerates you to 6500RPM and then bogs, only because you realized you didn't let go of the clutch pedal all the way.
OUCH Soldier! You just lost your race right there.
So you can adjust the switch the way you like it, but it's hard to find a perfect spot.
Old Aug 22, 2004 | 02:45 PM
NiceDc2r's Avatar
Default Re: Opinions and or Alternatives to Hondata 3 step (cpforyou)
so which msd unit has the 2 step
Old Aug 22, 2004 | 02:55 PM
allwhitehonda's Avatar
the fuel cutoff should not cause to many problems because the car is not under load therefore you will not detonate. HOWEVER its still not a very good thing. For the price you would be much better off getting an aftermarket piece. I think hondata wants $125 or some rediculous amount for their 3-step it dosnt cost them a red cent to include it with the s200 You are much better off just buying an aftermarket unit. That cuts the ignition.
Old Aug 22, 2004 | 07:16 PM
10000rpm's Avatar
buy msd digital 6 ignition it will make power and cheaper than buying hondata options
Old Aug 22, 2004 | 09:45 PM
NiceDc2r's Avatar
Default Re: Opinions and or Alternatives to Hondata 3 step (10000rpm)
yeah but dont you have to buy a coil and an msd dizzy cap???they will bring the price up
Old Oct 30, 2004 | 10:55 AM
#1151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NiceDc2r &raquo;</TD></TR><TR><TD CLASS="quote">yeah but dont you have to buy a coil and an msd dizzy cap???they will bring the price up</TD></TR></TABLE> thanks mom HAHAHAHAHAHAHAHA josh your ******* funny
Old Sep 2, 2005 | 03:01 AM
Cole D's Avatar
How about giving my money back for my lip......see my sig
Old Sep 2, 2005 | 05:58 PM
onepoint6i's Avatar
Default Re: Opinions and or Alternatives to Hondata 3 step (Cole D)
someone needs to handle their buisness
Old Sep 2, 2005 | 06:18 PM
2k.civic.si's Avatar
Default Re: Opinions and or Alternatives to Hondata 3 step (onepoint6i)
forget the hondata....use crome...crome does everything hondata does plus gear based fuel multiplier and individual cylinder trim.....and for a lot less
Old Sep 2, 2005 | 06:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cole D &raquo;</TD></TR><TR><TD CLASS="quote">How about giving my money back for my lip......see my sig </TD></TR></TABLE>
why would he refund you? it wasnt his fault ups lost it...if you want your money back do what everyone else does...file a claim with ups...duh
Old Sep 2, 2005 | 09:06 PM
beerbongskickass's Avatar
Default Re: Opinions and or Alternatives to Hondata 3 step (2k.civic.si)
Every car has full throttle launch and full throttle shift... it's called the rev limiter.
Old Sep 6, 2005 | 06:29 PM
Cole D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si &raquo;</TD></TR><TR><TD CLASS="quote">
why would he refund you? it wasnt his fault ups lost it...if you want your money back do what everyone else does...file a claim with ups...duh</TD></TR></TABLE>
I contacted UPS and I couldn't file a claim UPS said the sender had to file it and he promised he would I checked up with him form time to time and he said everything was fine then all of a sudden he disappeared and banned me from posting on the original post I'm screwed out of $85
Old Sep 7, 2005 | 09:12 AM
I contacted UPS and I couldn't file a claim UPS said the sender had to file it and he promised he would I checked up with him form time to time and he said everything was fine then all of a sudden he disappeared and banned me from posting on the original post I'm screwed out of $85 </TD></TR></TABLE>
then someone was screwin with ya....cause ive called in and made a claim and a day later a ups guy came to my house and i had to sign some papers then they reimbursed me
xDicktonesx
51
Nov 11, 2006 11:16 AM
vtekthis
Feb 13, 2004 05:44 PM
K20Ahondas
Nov 13, 2003 06:02 PM
Stroker
Mar 8, 2003 03:20 PM
