Can i install a low temp thermostat without replacing the fan switch??
Old Aug 22, 2004 | 11:27 AM
JD95hatch's Avatar
Default Can i install a low temp thermostat without replacing the fan switch??
i bought a low temp thermostat and am a few minutes away from installing...but i know with the mugen setup, you need to replace the fan switch if u buy their thermo.....do i have to replace the switch as well?
also the stock thermostat kicks in at 190 degrees correct?
Old Aug 22, 2004 | 11:47 AM
JD95hatch's Avatar
Default Re: Can i install a low temp thermostat without replacing the fan switch?? (JD95hatch)
bump..need a quick answer.
Old Aug 22, 2004 | 12:25 PM
jmk2888's Avatar
I have installed the Thermostat w/o the Fan switch on my ITR Engine.
No problems, temp. stays low.
Also you do not have to get a Fan Switch. it'll work w/o it.
Old Aug 22, 2004 | 12:35 PM
Deemeetree's Avatar
Electrician
Why not stick to an OEM unit?
Old Aug 22, 2004 | 01:00 PM
JD95hatch's Avatar
Default Re: (Dimi)
im plannin on makina 14 hour trip soon and my engine last few days has ran hot, so its a band-aid fix to mmy problem just to get me down there.
thanks for the answer!
fathergoose
Jan 31, 2005 02:12 PM
mika
Aug 9, 2004 05:34 PM
ATS*Mark
Dec 9, 2003 11:08 PM
biggtopscott
Sep 5, 2001 06:44 AM
