ok, this might have been covered...
Old Aug 22, 2004 | 09:16 AM
mr_valentino20032000's Avatar
Default ok, this might have been covered...
ok i have till monday or tuesday at best to have my car 100% ready for a engine getting swapped in.
I'm stuck on the axle removal. It seems to be really rusted in there, i got the other one out no problem, but as of now all my neighbors are pretty damn mad about the past 3 hours of banging on it with a hammer. I've tryed spraying WD-40 in the little inset, i've tryed brake cleaner....all this crap and nothing has happened. If i can find one to borrow i might resort to a few good hits with a small sledge hammer.
Other than brute force what else can i do?
Thanks guys
Old Aug 22, 2004 | 09:27 AM
91sihatchback
Guest
Posts: n/a
stick a flat head screwdriver in between the axle and the tranny and pry it out...come on man duh
REVS-2-9K's Avatar
Default Re: ok, this might have been covered... (mr_valentino20032000)
Heat it with a torch, over and over that might break it loose
Old Aug 22, 2004 | 09:29 AM
Default Re: ok, this might have been covered... (REVS-2-9K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91sihatchback &raquo;</TD></TR><TR><TD CLASS="quote">stick a flat head screwdriver in between the axle and the tranny and pry it out...come on man duh</TD></TR></TABLE> no i mean the side where it slides into the brake rotor part. Its rusted to hell
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REVS-2-9K &raquo;</TD></TR><TR><TD CLASS="quote">Heat it with a torch, over and over that might break it loose</TD></TR></TABLE> i never thought of that, so just heat it and it should be fine??? Oh yeah then beat it out?
Old Aug 22, 2004 | 09:32 AM
88turdbucket's Avatar
they make a four finger gear puller that can attach to your studds and then it pushes it out through the front side. let me see if i can find out where we got it from thats what we use on miatas that we tear apart..
Old Aug 22, 2004 | 09:36 AM
Its called a hub puller their are not cheap but they will get the job done we bought ours from a used tool company called williams tool i know you are not in texas but just to give an idea.. and it was 150.00 for ours if you want a pic i can email you a pic of it i cant figure out this pic hosting crap ....
Old Aug 22, 2004 | 09:38 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: ok, this might have been covered... (88turdbucket)
Pickleforks rule!
Old Aug 22, 2004 | 09:41 AM
Default Re: ok, this might have been covered... (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88turdbucket &raquo;</TD></TR><TR><TD CLASS="quote">Its called a hub puller their are not cheap but they will get the job done we bought ours from a used tool company called williams tool i know you are not in texas but just to give an idea.. and it was 150.00 for ours if you want a pic i can email you a pic of it i cant figure out this pic hosting crap ....</TD></TR></TABLE> DAMN, maybe..hopefully **crosses fingers** auto zone will have it under the rent a tool thing. Or maybe i can just get another bigger puller. Thanks i can see what you all mean. And either that or i have to find a torch
Old Aug 22, 2004 | 10:06 AM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_valentino20032000 &raquo;</TD></TR><TR><TD CLASS="quote"> I've tryed spraying WD-40 in the little inset, i've tryed brake cleaner </TD></TR></TABLE>
You should buy some pb blaster or liquid wrench. And whats the problem, is the axle nut off, or is the axle just stuck in there ?
Old Aug 22, 2004 | 10:11 AM
Default Re: ok, this might have been covered... (90blackcrx)
yeah the nut came off with almost no trouble. but now it has to slide out..it isn't working..now PB blaster, i'll get that later on today. But thanks guys.
Old Aug 22, 2004 | 11:48 AM
vtecn8ive's Avatar
Did you take the axle out of the the tranny?? maybe its just stuck against there. Is it moving at all?? Just put the axle nut on lightly (not snug) and then wail on it with a nice size Hammer.
Old Aug 22, 2004 | 12:41 PM
SETI20's Avatar
Have someone pull the rotor back, and give the axle a few dood whacks with a rubber hammer.
Old Aug 22, 2004 | 03:11 PM
Default Re: (SETI20)
Tap the end of the axle, the part thats sticking out of the hub. This will break any rust build up in there.
Old Aug 22, 2004 | 03:14 PM
Default Re: (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Tap the end of the axle, the part thats sticking out of the hub. This will break any rust build up in there.</TD></TR></TABLE> I've been beating on it for 3 hours and it didn't move at all.
Old Aug 22, 2004 | 03:24 PM
warchild69's Avatar
Default Re: (mr_valentino20032000)
well i have owned 10 honda's now and they have all been a pain to get the axel's out.... i am also a machinist...... if you hit the head of the axel to hard it will flare and you will never get it out. period.... best thing to do is remove the bolt for the lower control arm on the frame..... then the lower shock mount,.... tierod end, and the bar the conects to the crossmember off of the crossmember, and the upper mount..... then take it to a machine shop, or auto place that has a bearing press.... will cost you like 2 to 5 dollars.... you can usually drop the whole steering knuckle in about 20 min if you are good..... if you cant do this then take a cutting torch and just heat the axel untill it is red.... (dont squeeze the handle on the torch!!!) you dont want to cut it out... just heat it real good.... let it cool untill you can just touch it..... then beat that bitch with a dead blow hammer...... if you dont have a dead blow hammer........... buy one you will need it again im sure..... good luck....
Joey.
10
Dec 9, 2007 07:49 PM
DarkBB4
Apr 22, 2007 09:29 PM
Rocks
15
Jul 5, 2004 04:48 PM
Bense
May 30, 2004 04:19 PM
Red_Si
Sep 23, 2003 04:03 PM
