spoon cluster problem
Old Aug 22, 2004 | 07:05 AM
sihatch19's Avatar
Default spoon cluster problem
I just bought a brand new dc2 spoon gauge cluster and installed it in my integra and the feul gauge doesn't work. I though maybe it might read a different ohm as far as ohms full and ohms empty but I though t i would check with ht members before i call up the guy that i ordered it from. It was still sealed in the wrapping when it got it . thanks for any ideas
Old Aug 22, 2004 | 07:50 AM
Mr.DC2's Avatar
Default Re: spoon cluster problem (sihatch19)
did you bought the one on ebay with only 18km? if so, i was very tempted too.
what year is your integra? i think the spoon clusters are all 98 spec which will not work properly on 94-97 integras. your fuel and temp gauges may not work.
this is a common problem with the jdm itr cluster as well since 96 spec only works on 94-97 tegs and 98 spec only works on 98-01 tegs. they can fix this problem by swapping the green film on the back of the cluster. however, yours is spoon so i am not quite sure if that will work but you can always try.
Old Aug 22, 2004 | 10:11 AM
Seedc2's Avatar
what year is your integra? If its 94-97 its not going to work. Just like the guy above mentioned wapping out the green film might solve your problem.
how much did you get it for?
Old Aug 22, 2004 | 11:57 AM
sihatch19's Avatar
the car is a 99 but the box that the cluster came in do say it 96 spec. yopu think i can change the film and it will work
Old Aug 22, 2004 | 12:00 PM
Mr.DC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sihatch19 &raquo;</TD></TR><TR><TD CLASS="quote">the car is a 99 but the box that the cluster came in do say it 96 spec. yopu think i can change the film and it will work</TD></TR></TABLE>
hmm....learn something new everyday! guess if i ever want a spoon cluster, i should look for a 96spec.
yeah, just try swapping the green stuff. at least its reversable if it does not work.
Old Aug 22, 2004 | 02:06 PM
Dan GSR's Avatar
Default Re: spoon cluster problem (Mr.DC2)
give it to me, i'll give you my brand new ITR cluster
Old Aug 22, 2004 | 03:36 PM
sihatch19's Avatar
Default Re: spoon cluster problem (Dan GSR)
i swapped the green backing over and it worked thanks guys
tegracer19
Jun 9, 2009 06:02 PM
Black R
Apr 30, 2005 10:03 AM
Accord94DX
Sep 14, 2004 05:53 AM
the big ragu
May 6, 2002 06:10 PM
