spoon cluster problem
I just bought a brand new dc2 spoon gauge cluster and installed it in my integra and the feul gauge doesn't work. I though maybe it might read a different ohm as far as ohms full and ohms empty but I though t i would check with ht members before i call up the guy that i ordered it from. It was still sealed in the wrapping when it got it . thanks for any ideas
did you bought the one on ebay with only 18km? if so, i was very tempted too.
what year is your integra? i think the spoon clusters are all 98 spec which will not work properly on 94-97 integras. your fuel and temp gauges may not work.
this is a common problem with the jdm itr cluster as well since 96 spec only works on 94-97 tegs and 98 spec only works on 98-01 tegs. they can fix this problem by swapping the green film on the back of the cluster. however, yours is spoon so i am not quite sure if that will work but you can always try.
what year is your integra? If its 94-97 its not going to work. Just like the guy above mentioned wapping out the green film might solve your problem.
how much did you get it for?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sihatch19 »</TD></TR><TR><TD CLASS="quote">the car is a 99 but the box that the cluster came in do say it 96 spec. yopu think i can change the film and it will work</TD></TR></TABLE>
hmm....learn something new everyday! guess if i ever want a spoon cluster, i should look for a 96spec.
yeah, just try swapping the green stuff. at least its reversable if it does not work.
Black R
Apr 30, 2005 10:03 AM
Accord94DX
Sep 14, 2004 05:53 AM
the big ragu
May 6, 2002 06:10 PM
I just bought a Spoon Meter Assembly( Spoon gauge Cluster ) and there is a problem with a wiring har
p0oty
Dec 20, 2001 06:33 PM
