Pros & Cons of H22 Swap
Old Aug 22, 2004 | 02:11 AM
Insperation's Avatar
Default Pros & Cons of H22 Swap
Considering a JDM H22 Type S swap into my 99 Civic couple. What are the ups & downs of this setup. If its not a good idea, am going with plan B, JDM ITR swap.
I would also like to know which motor has better Top End. H22 or B18C5. I know already that the H22 is a torque monster!
Old Aug 22, 2004 | 02:45 AM
jdmh22eg's Avatar
h22 type S, my h22eg made 181whp 153tq and my homies itr eg made 175whp 134tq both with just v-afc and i/h/e... It all depends on what u want...and how much money u got...if you just want to drag get the H....if u want to do a little road racing then get the itr...peace
Old Aug 22, 2004 | 05:15 AM
Default Re: (jdmctreg93)
Am looking at Drag racing and a little free way chasing. I also was woundering do I have to change out my suspension on my Civic.
Old Aug 22, 2004 | 01:19 PM
cpforyou's Avatar
Default Re: (Insperation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Insperation &raquo;</TD></TR><TR><TD CLASS="quote">a little free way chasing </TD></TR></TABLE>
Old Aug 22, 2004 | 03:08 PM
allwhitehonda's Avatar
Default Re: Pros & Cons of H22 Swap (Insperation)
I have the h22a swap in my 94 hatch and I love it. A friend of mine has 96 Civic Coupe With same swap. Handling is not a big issue. Its all in the setup. If you do the Ground Control H22a swap coil overs with kyb agx gas struts HCP or Hasport motor mounts and a rear battery swap you will be handling better than you are right now guarunteed.
if thats still not good enough for you then do GSR front brakes gsr front sway bar and a comptech rear swaybar tiebar combo with trunk and engine bay brace.
you can do all that for around the price of an itr swap AND you needed to do it anyways to get your car turning well.
also youll need to buy new axels you can get them for $70 a piece from napa after you turn in your stock axels the axels do not need to be the same exact because napa wont check. for my car they are 93 integra axels and a accord intermediate i think its the same for yours but not 100%...
Also wether you do a itr or h22a you will be looking at a new radiator... the del sol dual core is plenty HOWEVER if you are not going to run a/c then i would recommend doing a GSR radiator because its much bigger and is also a dual core YOU will have to do some light fabrication...
also scrap the a/c and power steering to save some weight in the front... and again the battery swap is a big deal because you are taking 25 lbs from the front and puting it in the back so the a 50lb differance right there....
furthermore on suspension set up once you have adjustable struts coil overs and the sway bar you have a ton of stuff you can dial in and as long as you do it right i bet you will be able to outhandle any other front wheel drive honda that you run into because
most people just get coilovers
Old Aug 22, 2004 | 06:06 PM
GOLDBERG's Avatar
Default Re: Pros & Cons of H22 Swap (allwhitehonda)
not sure why all these people make like the H is so heavy..the swap(longblock+tranny etc) is 35lbs heavier..WHOOPIE fuc*in dooooooooo
Old Aug 22, 2004 | 08:32 PM
evilone's Avatar
Default Re: Pros & Cons of H22 Swap (GOLDBERG)
h22 shifts like **** compared to a type r.....
Old Aug 23, 2004 | 02:24 AM
Am planning on doing a GS-R Suspension setup anyways. Also doing a brake conversion to a GSR brake system. Sturt & sway bars are on the way. Am gonna lose the power steering anyways, but still debating if I want the A/C or not. Its pretty hot & sticky here in VA during the summer. Also another Q's is that am planning on going with the JDM H22 Type S swap. What header is good for this motor & I was planning on Port & Polishing the head for more breathing room. Is it nessary to Port & Polish it for not? I want to hit Mid-to High 12's All-Motor on street tires drag radials
Old Aug 23, 2004 | 03:06 AM
jdmh22eg's Avatar
Default Re: Pros & Cons of H22 Swap (prostockcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prostockcrx &raquo;</TD></TR><TR><TD CLASS="quote">h22 shifts like **** compared to a type r.....</TD></TR></TABLE>
i eat type r 's for breakfast and sumtimes dinner....
Old Aug 23, 2004 | 10:23 AM
Eddiebx's Avatar
Default Re: Pros & Cons of H22 Swap (jdmctreg93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmctreg93 &raquo;</TD></TR><TR><TD CLASS="quote">
i eat type r 's for breakfast and sumtimes dinner....</TD></TR></TABLE>
you eat pieces of **** for breakfast?
Old Aug 23, 2004 | 06:30 PM
evilone's Avatar
your the man now!!!!
so much for this thread, if you spell as well as you shift than you're more than likely starving.
Old Aug 23, 2004 | 08:10 PM
DriveSideWays's Avatar
how much does a complete swap wit all nessary parts and mounts cost for a h22?
Old Aug 24, 2004 | 02:53 AM
jdmh22eg's Avatar
Default Re: (DriveSideWays)
, if you spell as well as you shift than you're more than likely starving. </TD></TR></TABLE>
let me correct that for you...sometimes...
Old Aug 24, 2004 | 06:02 AM
H23vtecEG's Avatar
i love H-series. so should you
Old Aug 24, 2004 | 07:10 AM
JDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DriveSideWays &raquo;</TD></TR><TR><TD CLASS="quote">how much does a complete swap wit all nessary parts and mounts cost for a h22?</TD></TR></TABLE>
if you shop around you can get it done for under $5000, and thats with some aftermarket goodies... type s cams, springs retainers, bolts, etc
Old Sep 2, 2004 | 12:18 AM
GOLDBERG's Avatar
then put the itr tranny on the h22...doh!!
Old Sep 2, 2004 | 06:07 AM
hybrid_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG &raquo;</TD></TR><TR><TD CLASS="quote">not sure why all these people make like the H is so heavy..the swap(longblock+tranny etc) is 35lbs heavier..WHOOPIE fuc*in dooooooooo</TD></TR></TABLE>
Yeah really, I hate hearing this on a daily basis why ppl dont want to do an H22 swap b/c it is too heavy!!
Old Sep 2, 2004 | 06:08 AM
DrunkNRacer's Avatar
dont expect to be carving serious corners with the added weight to the front end. The h22 is alot heaver than any b18 engine. Granted, it is a torque monster, but the b18 has much greater top end power.
Old Sep 2, 2004 | 08:05 AM
Mike95lude's Avatar
Default Re: Pros & Cons of H22 Swap (DrunkNRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrunkNRacer &raquo;</TD></TR><TR><TD CLASS="quote">Granted, it is a torque monster, but the b18 has much greater top end power. </TD></TR></TABLE>
No it doesn't. It revs higher in stock form, but that is all.
Old Sep 2, 2004 | 11:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrunkNRacer &raquo;</TD></TR><TR><TD CLASS="quote">dont expect to be carving serious corners with the added weight to the front end. </TD></TR></TABLE>
Tell that to the guy w/ the H22 in an integra that runs in the East Coast Honda challenge and see what he says? You can also ask a buddy of mine stationed here with me in San Diego that has a H22 in his hatch that question, b/c he has no problems!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrunkNRacer &raquo;</TD></TR><TR><TD CLASS="quote">The h22 is alot heaver than any b18 engine. </TD></TR></TABLE>
Its only like a 40 lb. difference!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrunkNRacer &raquo;</TD></TR><TR><TD CLASS="quote">. Granted, it is a torque monster, but the b18 has much greater top end power. </TD></TR></TABLE>
I doubt that, you may want to do some research!
Old Sep 2, 2004 | 02:10 PM
meanEG's Avatar
H22 SWAP IS THE WAY TO GO. i like mine alot. at 222whp, i think my car is plenty fast. i ahve seen relativly stock h22's put down 200 to 210 whp.
2gen hatch
Mar 6, 2008 07:47 PM
crvtec10
26
Sep 8, 2006 03:34 PM
acclude23vtec
Oct 31, 2005 04:59 PM
SlippylesKB
Jun 3, 2003 08:59 PM
