Will Any B series injectors fit any B series Motor
Old Aug 22, 2004 | 12:06 AM
FunIntegras's Avatar
Default Will Any B series injectors fit any B series Motor
Hi,, I have a 92 Acura Integra GSR with a B17A VTEC motor and the fuel injectors are bad. I was wondering if any one know if any B series injectors will fit? And if it does which model injectors would be the best and the difference?????
Or should I got after market with something over 400CC?
B18A Non Vtec
B18B Non vtec
B18C Vtec
Thanks for looking. Hope you can help
Old Aug 22, 2004 | 12:31 AM
H22A EG6's Avatar
Default Re: Will Any B series injectors fit any B series Motor (FunIntegras)
yupper they should and some mitsu DSM injectors should fit also
but some will have different flow rates
Old Aug 22, 2004 | 12:48 AM
3.504's Avatar
Default Re: Will Any B series injectors fit any B series Motor (H22A EG6)
all b-series are 240cc. different obd injectors have different plugs, so you'd need to swap plugs or modify the ones you have. dsm's are saturated and need a resistor box as are prelude vtec's (93-96).
as for going bigger: depends what you have done. if you have n/a bolt ons even w/ small amount of nitrous, you wont need bigger. any forced induction would pretty much need bigger. built all motor needs bigger when passing the 180ish whp mark... all depending.
Old Aug 22, 2004 | 05:09 AM
DriveSideWays's Avatar
coo i needed to know that too
Old Aug 22, 2004 | 10:38 PM
Default Re: Will Any B series injectors fit any B series Motor (3.504)
Thanks.
Xperience
Mar 4, 2013 10:15 AM
jfruauff
Sep 5, 2007 09:45 AM
Touge_EF
May 24, 2006 03:12 PM
96lsvteccivic
Feb 22, 2004 09:19 AM
civbeater90
Apr 15, 2002 05:32 PM
