Front LCa's / Camber kit install
Old Aug 21, 2004 | 08:31 PM
i3lazedx's Avatar
Default How do i install Front LCa's / Camber kit ??
ok i want to put the front lca's from a 94 ex onto my 95 dx so i can add the swaybar.. also im installing camber kits... i found some howto's for the camber kit but the lca's im not possitive on how to do it.
do i tighted all the bolts before i put weight on the car? or do u wait till weight is on the suspension to tighted them to spec.. any info will be good.. i took them off the other car its just im not sure how u install them,.,
i went to some local shops and they want like 300 to install the camber kits and the lca's / sway... i think thats alot of cash so i wanna do it myself... any how tos or advice would be great thx
Modified by i3lazedx at 9:57 PM 8/21/2004
Old Aug 22, 2004 | 12:38 AM
nwdave's Avatar
Default Re: How do i install Front LCa's / Camber kit ?? (i3lazedx)
You can compress the suspension with a jack and then tighten the bolts while the car is still in the air.
EkFerio808
Suspension & Brakes
May 25, 2009 08:08 PM
xTurtle714x
Apr 7, 2005 07:57 PM
down_the_hatch
Feb 8, 2005 12:51 AM
TexTeg
Jan 21, 2002 09:25 AM
Immortal23
Jul 16, 2001 08:24 AM
