Turn signal help!
Old Aug 21, 2004 | 06:26 PM
SYTFU Tommy.'s Avatar
Default Turn signal help!
all signals dont work. not even the lights on the cluster. any help would be nice. TIA
Old Aug 21, 2004 | 06:31 PM
njandrewg's Avatar
Default Re: Turn signal help! (tngay)
check ur fuse
Old Aug 21, 2004 | 06:36 PM
black_hatch's Avatar
check fuse box. One of the fuses will be for ur turn signals and for the instrument cluster. If that keeps blowing out, u might have a line with postive on ur alarm that is grounding. If you do have an alarm, it might also have a fuse that gets triggered when you turn the alarm on. This fuse will blow if your lines are crossed when you turn the alarm on, because the signal is sent to turn the alarm on and your lights will go on when it churps and ur instrument cluster should also turn on when ur alrm is triggered. If you don't have an alarm just try to change ur fuses. If it still does it try checking ur light bulbs. If one of them is suppose to be a two prong and you put a single prong -- that problem will occur.
----- hope this might be helpful to you. -------
Modified by black_hatch at 10:54 AM 8/22/2004
Old Aug 21, 2004 | 07:00 PM
Default Re: Turn signal help! (black_hatch)
i checked the fuses. its a 10 right and also its the middle row last one if i am correct? it was working fine the other day untill today when i change the bulbs on the cluster to amber
Old Aug 21, 2004 | 08:08 PM
bumps
Old Aug 22, 2004 | 12:50 AM
tekstyle's Avatar
check your blinker relay. it might have went bad. and check if ur hazard works. if it does, then u dun have to worry about a short
Old Aug 22, 2004 | 08:26 PM
Default Re: Turn signal help! (tekstyle)
ok, i got the signals to work. now the hazards doesnt work. nehelp on that? TIA
Old Aug 22, 2004 | 10:29 PM
bumps!
Old Aug 23, 2004 | 07:32 AM
bumpos
Dc295kid
Audio / Security / Video
Mar 15, 2009 04:13 AM
TheTealHatch
Dec 31, 2005 11:23 AM
vietjdmboi
Jun 25, 2004 09:18 PM
B18EG6
Feb 11, 2003 05:08 PM
