another damn nitrous question
knowing that a certain psi setting gets u different results depending on the turbo i.e.- 8psi on a 18G greddy vs 8psi on a drag. is different. well is sayy... 80shot dry nitrous equal to 80shot wet nitrous? in other words....will a dry setup bring up the same results as a wet setup under the same amount being sprayed?
[Modified by redteg1, 7:58 PM 12/3/2001]
A wet setup 80 shot will yield more HP then a dry 80 shot because the simple fact that there is fuel being mixed along with the jet in a wet setup and each one of those intake runners is getting exactly 20 shots of NOS, (direct port) For the wet setup to work properly bottler temp is very important. Keep it at 900 - 1000 psi otherwise you will bog down with too much fuel, not enough NOS.
[Modified by integra0260, 12:59 PM 12/3/2001]
Wet is also safe to run then a dry because fuel is always present with the NOS as it enters the motor, thats why you're suppose to run a wet setup (direct port) if your going with an 80 shot or more
[Modified by integra0260, 1:01 PM 12/3/2001]
Please see my reply to this sam question in this thread: https://honda-tech.com/zerothread?id=96440
