another damn nitrous question
Old Dec 3, 2001 | 10:52 AM
redteg1's Avatar
Default another damn nitrous question
knowing that a certain psi setting gets u different results depending on the turbo i.e.- 8psi on a 18G greddy vs 8psi on a drag. is different. well is sayy... 80shot dry nitrous equal to 80shot wet nitrous? in other words....will a dry setup bring up the same results as a wet setup under the same amount being sprayed?
[Modified by redteg1, 7:58 PM 12/3/2001]
Old Dec 3, 2001 | 11:57 AM
integra0260's Avatar
New User
Default Re: another damn nitrous question (redteg1)
A wet setup 80 shot will yield more HP then a dry 80 shot because the simple fact that there is fuel being mixed along with the jet in a wet setup and each one of those intake runners is getting exactly 20 shots of NOS, (direct port) For the wet setup to work properly bottler temp is very important. Keep it at 900 - 1000 psi otherwise you will bog down with too much fuel, not enough NOS.
[Modified by integra0260, 12:59 PM 12/3/2001]
Old Dec 3, 2001 | 12:00 PM
New User
Default Re: another damn nitrous question (integra0260)
Wet is also safe to run then a dry because fuel is always present with the NOS as it enters the motor, thats why you're suppose to run a wet setup (direct port) if your going with an 80 shot or more
[Modified by integra0260, 1:01 PM 12/3/2001]
Old Dec 3, 2001 | 12:40 PM
dyezak's Avatar
Please see my reply to this sam question in this thread: https://honda-tech.com/zerothread?id=96440
Old Dec 3, 2001 | 05:06 PM
captain4g63's Avatar
Another way of looking at this, as dyezak pointed out:
55hp = 55hp
65hp = 65hp
82.8hp = 82.8hp
[Modified by captain4g63, 2:07 AM 12/4/2001]
Old Dec 3, 2001 | 06:32 PM
redteg1's Avatar
Default Re: another damn nitrous question (captain4g63)
wat is that supposed to mean? hp is hp...no ****...are u meaning the relation of shot to hp? as in 50shot to 50hp?
Doug684
Jan 4, 2004 02:51 PM
-Racer X-
Jun 8, 2003 11:41 PM
2008cc
Mar 14, 2003 06:37 PM
el arbi
Dec 2, 2002 01:05 PM
B20-T
May 12, 2002 12:23 PM
