Wich OEM seats should I get for my 97 Civic EK?
Old Aug 21, 2004 | 04:46 PM
Lewis7789's Avatar
Default Wich OEM seats should I get for my 97 Civic EK?
Hey guys. I have a '97 2 door DX coupe and these stock seats aren't worth crap. I love racing seats but this is my daily driver and I need to get into the back seat, so I'd like something reclinable. But I'd like something with more side bolstering than these stockers for the corners. I found some 99-00 Si seats for $110 that I'm really interested in getting, but is there much of a difference between the Si's and my Dx's other than color? And the Si seats will bolt right into my Ek right? Seems like the Del Sol seats are the best but pretty rare to find...
Thanks for any advice and oppinions!
Old Aug 21, 2004 | 05:10 PM
enigma94's Avatar
Default Re: Wich OEM seats should I get for my 97 Civic EK? (Lewis7789)
del sols
Old Aug 21, 2004 | 05:26 PM
aZnjCC's Avatar
dont' waste ur time with Si seats. they are the EXACT same thing as ur dx seats except for a fancy headrest.
Get del sol's if you can find em, or get some integra seats. None of these seats will bolt right into your car. But a simple swap of the rails will allow it to bolt right in.
Old Aug 21, 2004 | 05:32 PM
JDM R's Avatar
Del sol seats or teg seats
Old Aug 21, 2004 | 05:35 PM
Daniel's Avatar
Default Re: Wich OEM seats should I get for my 97 Civic EK? (enigma94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by enigma94 &raquo;</TD></TR><TR><TD CLASS="quote">del sols </TD></TR></TABLE>
I installed them in my EJ8, and I absolutely LOVE them! Swap the rails/slider assembly from your Civic seats on the del Sol seats, and you're all set. Everything bolts together like stock, so there's no modding necessary. The only "modding" you'll need to do is rebend the slider wire, but if you have some pliers and arm muscle, it's easy. Check out my webpage for pics.
Old Aug 21, 2004 | 07:06 PM
EKNINE00's Avatar
get the new ep3 si seats they rock . i got em. a little cutting and welding though
Old Aug 21, 2004 | 07:11 PM
SiYouLater's Avatar
Default Re: (EKNINE00)
i have integra in my and they are far better than the si's.
Old Aug 21, 2004 | 07:14 PM
Quad-Damag's Avatar
Default Re: (99FBPSi)
I have Tan Leather GSR's 2 of them, one good, other has a few rips for 150 OBO Pickup in Bay ARea
Old Aug 21, 2004 | 07:16 PM
MissLady's Avatar
Default Re: (Quad-Damge)
i LOVE del sol seats...go with those
Old Aug 21, 2004 | 07:17 PM
hatchling37's Avatar
Default Re: (MissLady)
JDM ITR's
Old Aug 21, 2004 | 08:09 PM
murmur9's Avatar
Default Re: (hatchling37)
crx or del sole seats...teg's too
Old Aug 21, 2004 | 10:38 PM
StRacer's Avatar
Default Re: (murmur9)
I have 94 teg seats in mine, they fit great. I even have the back seats with a few mods. I got the back seats to match perfectly(the flip down parts) by switchin out the metal frames in the seats. But if you put the seat cushion on you will have a gap between the the back rest and the cushion.
Old Aug 22, 2004 | 10:39 AM
Lewis7789's Avatar
Thanks for the reply's guys. Looks like I'll pass on the Si seats and look for some Sol or Teg seats. Thanks again guys!
Old Aug 22, 2004 | 10:58 AM
flesh199's Avatar
Default Re: (Lewis7789)
great move lewis .. i have teg seat and love them so much
Old Aug 22, 2004 | 11:49 AM
m3dia_lab's Avatar
s2k, i saw a write up the other day on how to make the install correctly
Old Aug 22, 2004 | 11:52 AM
SprayinCX's Avatar
Default Re: (m3dia_lab)
del sol seats are awesome
here is my how to on the install
https://honda-tech.com/zerothread?id=958044
Old Aug 22, 2004 | 12:10 PM
Shocka1998LX's Avatar
I sat in prelude seats....they grabbed my body alot better than the del sol seats. I'm not a big guy though, so if you are... del sols might be better.... I'm only 5'7 and 135 lbs
Old Aug 22, 2004 | 12:12 PM
wdskuk's Avatar
SI seats equal DX seats except for the headrest
Old Aug 22, 2004 | 12:15 PM
MulletManRockStar's Avatar
Default Re: (wdskuk)
crx si seats if you can find some in excellent shape or if you can get em recovered for cheap. they are the nicest civic seats ive seen in usdm
Old Aug 22, 2004 | 12:18 PM
Daniel's Avatar
Default Re: (Shocka1998LX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shocka1998LX &raquo;</TD></TR><TR><TD CLASS="quote">I sat in prelude seats....they grabbed my body alot better than the del sol seats. I'm not a big guy though, so if you are... del sols might be better.... I'm only 5'7 and 135 lbs</TD></TR></TABLE>
Yeah, that's a good point. The reason I went with del Sols over GSRs is because GSR seats are too wide for my body (5'5" and 150lbs). I can sit in my brother's GSRs and still move laterally. With the del Sol seats, I'm literally HUGGED by the side bolsters. So check out a few seats before deciding. And I'm really glad I decided not to go with GSRs. I know I wouldn't have been as happy if I did.
Old Aug 22, 2004 | 12:22 PM
spock_rocker's Avatar
memoryFAB.com representative
Default Re: (Daniel)
i liked the GSR seats i had in my coupe.. but prelude seats hug nicely too.
Old Aug 22, 2004 | 01:28 PM
TallAssFilipino's Avatar
Default Re: (spock_rocker)
Prelude, Del Sols, JDM EG (w/the non-adjustable head restraints)
Modified by TallAssFilipino at 7:02 PM 8/22/2004
Old Aug 22, 2004 | 02:59 PM
LoSt is BlaCk's Avatar
Default Re: (TallAssFilipino)
del sol's or s2k's
Old Aug 22, 2004 | 10:24 PM
Ant-man's Avatar
Actually, difference between your DX seats & Si seats is more than just different colors. You can move your seats forward/back & adjust recline. 99-00 Civics, including Si, had additional adjustment by means of **** on side of seat. I don't remember what it did.
If I were to change my seats, I'd go w/ pair from Integra. Those have adjustable lumbar support.
----- Antony
PS: If you're looking for Del Sol seats, black w/ red stripe is most common, & therefore least expensive.
Old Aug 23, 2004 | 12:08 AM
JamesQ's Avatar
Default Re: Wich OEM seats should I get for my 97 Civic EK? (Ant-man)
del sols are nicest imo, besides s2k
