ITR or JE pistons?
Old Aug 21, 2004 | 03:44 PM
whiteyGSR's Avatar
ok, nvm. its now between:
spoon balanced ITR pistons
OEM CTR .25mm pistons
Old Aug 23, 2004 | 01:17 AM
Circuit Star-29's Avatar
Default Re: (whiteyGSR)
Well, your talking about two different setups here. You'll have to bore the motor for the .25mm over CTRs and the only thing about the spoon pistons is that they weigh the same. The question you should ask first is what your goal for this build is: Turbo, Supercharged or NA. The ctrs will be a good na piston, but the compression will be too high for TC or SC. there are too many variables to include when deciding what slugs to use. Talk to EARL, search his name and ask where you should start with your build... it really doesn't seem like you know where you want to go for the final product. Boost or Not, that is your question.
Old Aug 23, 2004 | 01:57 AM
3.504's Avatar
Default Re: (nathan atwell)
CTR's will yield over 12.:1 in a gsr motor. the JDM ITR's will be about 11.4ish. CTR's might run a little hot, as they are cast, at that compression. i know the p72 has oil jets, but over 12:1 c/r w/ cast pistons seems a little dangerous to me. i'd say go w/ the ITR's to be on the safe side.
blackeg
21
Jan 4, 2012 04:16 PM
lickety_britches
Mar 21, 2008 07:31 PM
truazn4lyfe
Jul 4, 2007 06:37 PM
PowerHouse
Oct 12, 2004 06:21 PM
216.226.142.95:27016
Sep 20, 2003 07:32 AM
