What's the best way to restore the blackness of the valve cover?
Old Aug 21, 2004 | 11:33 AM
Smeeg Heed's Avatar
Default What's the best way to restore the blackness of the valve cover?
Just like the title says. My valve cover is getting rather stained and washed out. Was just wondering if there's any way to make it dark black again.
Old Aug 21, 2004 | 11:37 AM
babyteg's Avatar
Default Re: What's the best way to restore the blackness of the valve cover? (Smeeg Heed)
engine paint
Old Aug 21, 2004 | 11:43 AM
lildevock's Avatar
Repaint it:
1. remove valve cover
2.remove old paint using aircraft paint remover.
3. Repaint with high temp engine paint. 500 degrees is fine
4. Replace valve cover gasket
5. put cover back on.
Old Aug 21, 2004 | 11:44 AM
3.504's Avatar
Default Re: What's the best way to restore the blackness of the valve cover? (babyteg)
strip the paint with aircraft striper. clean really well with soapy water and then rinse really good. paint with black crinkly paint, can find at walmart and such in the spray paint section of the home decorating or in the automotive section.
Old Aug 21, 2004 | 01:37 PM
iixerOii's Avatar
Default Re: What's the best way to restore the blackness of the valve cover? (3.504)
I used some simple green, scrubbed and washed it off. It did a pretty good job, but not as good as really taking it apart and repainting it.
Old Aug 21, 2004 | 01:54 PM
kid-honda's Avatar
Clean engine bay with engine bright/simple green then when dry spray ENTIRE bay with mothers or whatever dash and plastic cleaner you like to use then shut the hood, turn car on and let "bake" and everything in your bay will look brand new including the valve cover.
Old Aug 21, 2004 | 02:23 PM
m3bluegsr's Avatar
Default Re: (kid-honda)
if you want it to shine use wd-40 to clean it.
jsteezy1290
18
May 12, 2004 08:59 PM
Dirk McGirk
Oct 3, 2003 08:00 PM
vicz
Apr 10, 2003 02:02 PM
ih8danoles
Oct 27, 2002 01:22 PM
integranator
Oct 1, 2002 06:15 PM
