Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
AEM fuel rails and AEM fuel pressure regulators - in stock!
Old Aug 21, 2004 | 09:41 AM
prostreetonline's Avatar
Default AEM fuel rails and AEM fuel pressure regulators - in stock!
These billet aluminum AEM fuel pressure regulators can support engines up to 1,000hp. Featuring replaceable discharge ports to match your fuel pump output, they're adjustable from 20psi up to the maximum pump capacity rating.
Click here for AEM Fuel Pressure Regulators
AEM High Volume Fuel Rails are CNC machined from 6061 T-6 billet aluminum and feature a 1/2 inch fuel bore capable of flowing enough fuel to support most high-performance engines. This larger bore also dampens the back pulse created by oversized injectors in high-output applications. The AEM fuel rail also works perfectly with stock injectors. Each fuel rail includes an additional port for the installation of a nitrous set-up or external fuel pressure gauge. The ends of the fuel rail are tapped to accept either -6 or -8 line and a custom fitting allows for the use of the stock fuel hose. AEM's High Volume Fuel Rail kit includes new injector o-rings, fuel line fittings, comprehensive installation instructions and AEM decals.
Key Features:No additional parts required.
Specifically engineered for each application.
Each kit is available powdercoated in Blue, Red, Silver and in a mirror polished finish. Please designate which color you wish in our
Click here for prices and applications for AEM Fuel Rails
Available in blue, red and silver with laser-eched graphics, for show quality look. Manufactured and assembled in the USA.
Click here for prices and applications for AEM Fuel Filters
MOST APPLICATIONS IN STOCK!
DA TeG 90
Jan 27, 2010 03:10 PM
explictness
Aug 12, 2004 11:00 AM
typertn
Jan 9, 2004 11:58 PM
allmotorjay
Jun 27, 2003 04:28 PM
