Can i wire a Primary 02 to Secondary o2 the SAME????
Old Aug 21, 2004 | 09:33 AM
mugenhatch92's Avatar
Default Can i wire a Primary 02 to Secondary o2 the SAME????
I was just wondering if i can wire a primary o2 sensor up in the secondarys spot? and will it work that way?
Old Aug 21, 2004 | 09:35 AM
Redline96LX's Avatar
* B A N N E D *
Default Re: Can i wire a Primary 02 to Secondary o2 the SAME???? (mugenhatch92)
naw theres 2 O2 sensors for a reason. The first reads rich and lean, in a sinusoidal wave, going from rich to lean. the second O2 sensor is to read the exhaust (clean now) to make sure the cat is doing its job. Theres aftermarket computers to **** your ECU into thinking the second O2 sensor is workin, allowing no cat.
Old Aug 21, 2004 | 09:37 AM
alright thankyou very much
Old Aug 21, 2004 | 09:38 AM
slambedcivic's Avatar
its been done. usually the car runs slightly richer than it should. but it will only help later on down the road for when you do more mods to increase air flow.
were running an 89 STD hatchback with a JDM B16A, with jumped 02 sensors. weve not had any problems
bbhockey19
Oct 31, 2006 04:03 PM
quik89
Jul 24, 2004 03:40 PM
jcivic
Apr 24, 2003 01:51 PM
Aphrodavid
Dec 15, 2002 04:50 PM
radiac
Jul 5, 2001 08:45 PM
