Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
Ground Control Coilovers
Old Aug 21, 2004 | 09:20 AM
prostreetonline's Avatar
Default Ground Control Coilovers
Ground Control Coil-over kits are designed and built in USA for American roads. A sophisticated dyno on-car data acquisition are used to create the perfect balance between looks, ride, and performance. No universal kits with mystery springs. All Ground Control kits use Eibach springs giving Ground Control best selection of applications in their class. Ground Control kits have the exclusive on-hand locking perch. Just one hand loosens for easy adjustment, then clamps tightly around the adjuster to keep dirt, sand, and salt from jamming the threads. The Milspec type II andoized finish prevents corrosion.
Click here for the full application of Ground Control Coilovers
MOST APPLICATIONS IN STOCK!
Old Aug 21, 2004 | 12:57 PM
mstewar's Avatar
Default Re: Ground Control Coilovers (prostreetonline)
can I get a quote shipped for a 2001 Prelude SH to 62298?
Also, I may need a set for my ITR, but I would need custom rates.. Would that be possible and what would that cost?
Old Aug 28, 2004 | 05:04 PM
clemsoncb7's Avatar
Default Re: (prostreetonline)
How much for a 94 prelude vtec?? Thanks
Old Aug 28, 2004 | 05:10 PM
Default Re: (maxvtec7500)
$322.05.
Thanks!
Old Aug 30, 2004 | 05:13 PM
Default Ground Controls
Ground Controls
Old Sep 1, 2004 | 11:11 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
whats the differenance between the integra's, coil over, and the "limited edition" coil over?
Old Sep 1, 2004 | 11:54 AM
vitrox's Avatar
what does it mean by shock: 1,2,3,7,8,10?
Old Sep 2, 2004 | 09:26 AM
Default Re: (vitrox)
It says on the bottom of the page, it's a code for you to be able to tell what kind of shocks it'll work with, etc.
Old Sep 2, 2004 | 09:35 AM
Default Re: Ground Control Coilovers (Built B16A)
I think it's because they offer a bigger lowering range with a certain range of shocks than the standard ones.
Old Sep 2, 2004 | 07:07 PM
Built B16A's Avatar
so spring rates are still the same in both applications?
Old Sep 4, 2004 | 06:40 PM
Seems that they are the same. Thanks!
Old Sep 4, 2004 | 08:21 PM
choNy's Avatar
How much for an EP3, Pm me price Thx
Old Sep 6, 2004 | 07:21 PM
ewaugh's Avatar
Default Re: Ground Control Coilovers (choNy)
How 'bout a 91 Civic Si w/ Koni yellow's?
Old Sep 8, 2004 | 11:18 AM
Default Re: Ground Control Coilovers (ewaugh)
CHeck here if we have it:
http://www.prostreetonline.com...a.asp
Thank you!!
Old Sep 12, 2004 | 07:02 PM
phil2000's Avatar
Can you supply alternate spring rates with the GC coilover kit?
IE...a 93 Prelude kit with 380/450 instead of whatever it comes with.
Thanks.
Old Sep 13, 2004 | 11:00 PM
Default Re: Ground Control Coilovers (phil2000)
Yep!
Custom rates are $50 more, and take about one week to get.
Old Sep 15, 2004 | 02:51 AM
Mischiefek
Guest
Posts: n/a
how much are thse for honda civic?
Old Sep 15, 2004 | 10:14 PM
Default Re: (Mischiefek)
Check here:
http://www.prostreetonline.com...overs/
Old Sep 19, 2004 | 07:09 PM
95Sol's Avatar
pm sent
Old Sep 19, 2004 | 11:01 PM
uNF$@#!'s Avatar
how much does shipping run usually?
I'm based in NY at the moment.
Old Sep 20, 2004 | 08:51 AM
To NY, probably about $15. When you order online, our shopping cart will tell you directly from UPS.
Thanks!
Old Oct 5, 2004 | 01:40 PM
137's Avatar
137
how much for a set with 300f ers springs and 380 rear ers springs shipped to 92336
Old Oct 8, 2004 | 07:57 PM
Default Re: Ground Control Coilovers (137)
email me at alex@prostreetonline.com and I'll find out for you first thing monday morning...
thanks!
Old Oct 14, 2004 | 05:58 PM
BlueShadow's Avatar
Hello,
I was thinking about gettins some GC's for my 91 CRX DX. Can you guys get them in custom sprin rates? I was thinking about going with some 450 FRONT and 350 REAR for my setup.
I also wanted to get some Koni Yellows to go along with the GC's. However, I didnt see an applications for CRXs on your site. Do you guys have these available too? How much would it be for the GCs? and if ou can get the Konis too, how much for the GCs + the Koni Yellows?
Thanks
Old Oct 19, 2004 | 04:54 PM
Default Re: (BlueShadow)
Sent you an email.
