Quick timing question
Which way do I turn the Dizzy to advance the timing? Towards the radiator or torwards the firewall?
I have a d series in my Eg.
The reason I want to advance is becasue I run REALLY rich. It was dyno tuned that way becasue in the upper RPM i was losing fuel pressure and running lean.
But its running even richer than it was back then, so I thought I would advance it a degree or two.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miahmouse »</TD></TR><TR><TD CLASS="quote">how bout using a timing gun?</TD></TR></TABLE>
that doesnt tell you which way to turn the dizzy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Teal »</TD></TR><TR><TD CLASS="quote">
that doesnt tell you which way to turn the dizzy</TD></TR></TABLE>
yes it does,, you can tell my monitering the marks on the crank.
so you're going to just start randomly turning the distributer in unmeasured amounts and expect to produce anything positive? .... on a car that had been on the dyno and is known to lean out up top?
