what do u think...phantom grip
Old Aug 20, 2004 | 11:59 PM
kikobrat's Avatar
Default what do u think...phantom grip
I want to get a diff, cuz im turbocharging my gsr, i dont want to spend a whole lot, but besides phantom grip are there any other recommendations (same price range) or do any of u use one???? thanx
Heather
Old Aug 21, 2004 | 12:48 AM
3.504's Avatar
Default Re: what do u think...phantom grip (kikobrat)
phantom grip is junk IMO. back when hondaprelude.com was up (and i owned a prelude) there was no LSD for 3rd gen ludes besides the PG. a guy installed it, drove it, didn't feel any LSD effects. he then took the tranny back apart, installed more washers under the load springs in the PG, went for a drive and said it was awesome. two days later he came back and posted that he felt no effects again. i've never heard much good from the PG.
i would recommend an OEM LSD... good up to a little over 200whp. after that i'd say quife (sp?) is going to be your best bet.
theres is the cheap way. weld the spider gears
Old Aug 21, 2004 | 12:52 AM
.water's Avatar
Default Re: what do u think...phantom grip (3.504)
ebay has good one..guy from Japan selling it.. off from ITR cusco brand
Old Aug 21, 2004 | 04:48 AM
Integralove00's Avatar
Default Re: what do u think...phantom grip (Spoon Type-One)
Heather,
Phantom grip is called that because you won't even know that it is in there. If you aren't willing to spend the money for good parts you are only wasting your money on bad parts. It is pretty much like the other guy said you could use the R LSD which I believe requires use of the R final drive as well. Quaife is best for most daily driven cars because it doesn't require alot of maintenance and it is guaranteed for life . There are several types of diff's if you don't already know. The R and the Quaife are both "helical", brands such as Cusco and ATS are clutch type. Clutch type LSDs require a routine break down to replace the clutch discs. Clutch types are also recommended for race cars more than daily drivers. There is soo much more.... I recommend Quaife and only Quaife.. regardless of your budget just save the money ($895 shipped) and do it right the first time..
Just my opinion
Modified by Inte9ralove00 at 12:01 PM 8/21/2004
Old Aug 21, 2004 | 06:37 AM
stasi's Avatar
kikobrat, please use the search feature. There was a long *** thread about this not long ago. Thanks.
Old Aug 21, 2004 | 09:05 AM
iBrandon's Avatar
Default Re: what do u think...phantom grip (stasi)
Junk!...
Old Aug 21, 2004 | 08:51 PM
Badger401's Avatar
Default Re: what do u think...phantom grip (Shy Gsr)
the phantom grip does not work, its just like welding the axles together so they both spin together. Now think about what happens when you take a turn, your outside wheel wants to spin faster than your inside wheel....
Old Aug 21, 2004 | 10:46 PM
kikobrat's Avatar
Default Re: what do u think...phantom grip (Badger401)
thank u guys, ur right, i should spend more for good parts. im gonna go w/ the quaiffe im new to this, my dad owns a shop, and i had a b/f that was helping me, not anymore. so this is why im on the board now. thank u so much for all your help.
heather
Old Aug 23, 2004 | 03:42 PM
vtecmissle's Avatar
actually obx makes a reproduction of the itr lsd fro about 350 dollars. No one here has tried it yet . http://www.groupbuycenter.com has it. The phantom grip mentioned above does work but has its downfalls. Some 10 second cars have run it. If you use it get the upgrade springs or you will have problems. The stock itr differential will work well over 200 horsepower. I have seen 400 easily and it is stronger than the gsr which i believe has held more than 600. I would say buy a r tranny and save time. I am going to try the obx differential very soon in my gsr tranny as i also have a jdm itr tranny with the 4,78 ratio. I would think you wouldnt need either untill you are making serious power and then it would only help so much.
Old Aug 25, 2004 | 01:30 PM
Default Re: what do u think...phantom grip (vtecmissle)
Actually, someone here has tried the OBX LSD.. there is a post on it on here with pictures..
Edit: Here is the link https://honda-tech.com/zerothread?id=925949
Old Aug 25, 2004 | 01:35 PM
jdmotorsports's Avatar
Default Re: what do u think...phantom grip (Inte9ralove00)
i'm running a phantom grip and have no real problems with it. on hard launchs both my front tires will spin. coming out of corners i do notice a difference. is it the best? no. if i had the money i would of gone with a quaife lsd. but i didnt have 900$ plus when i got the p.g. they didnt make a lsd for the 91 teg trans. i'm happy with the phantom grip. it was worth the price.
svtford4x4
13
Feb 20, 2012 09:17 PM
Honda Gen
Nov 28, 2007 08:09 AM
infumis
Jan 17, 2007 01:17 PM
flip1199
Aug 25, 2002 09:22 PM
