type r or gs-r
Old Aug 20, 2004 | 11:51 PM
allmotorbeasteg6's Avatar
Default type r or gs-r
ok heres my situation, im either thinking of building up a jdm b18c meaning im going to fully built the bottom end with pistons, rods, resleeve and bore the block to 85mm, and also have it balanced, flywheel, and clutch. as for the head, im probably just going to install from itr cams since im putting so much money into the block first. on the otherhand, get a jdm type r and leave the block to way it is which is stock. im probably just going to a clutch and a flywheel. i havent gotten an idea what imma do the head due to the type r costing so much. so here's my question, is building the gs-r block a better idea even though the head just have itr cams or is getting a type r motor a better idea due to the fact that the type r has other goodies that the b18c doesnt come with? any opinions will be greatly appreciated....
Old Aug 21, 2004 | 12:08 AM
SLCTyper's Avatar
Default Re: type r or gs-r (allmotorbeasteg6)
Are you planning to primarily drag race? If that's the case you might as well use the gs-r and not spend the extra cash on the R. If you are planning on getting into autocross, go with the ITR.
Old Aug 21, 2004 | 12:13 AM
Default Re: type r or gs-r (SLCTyper)
i wouldnt really say autocrossing, just a daily driven street car. its just that i can get a jdm gs-r for around $2800 and built the motor rather than just spending $4200-4400 just for a stock type r which only have better head and tranny. i just need some opinions on this matter...
Old Aug 21, 2004 | 12:19 AM
Haleiwa-Brando's Avatar
why would you get a jdm gsr engine? there is only a very slight difference in compression and your considering doing work to it anyways. Look on ebay....you can get a gsr engine for about $1,000.00.
Old Aug 21, 2004 | 12:23 AM
jdm_cars's Avatar
Street Car huh?
GSR+Turbo is what I would do, if you had the extra funds, I would go JDM98spec ITR tranny
Wasn't this covered already? a Turbo'ed GSR or a builtup GSR like you described will perform better than a stock ITR.
Old Aug 21, 2004 | 12:28 AM
uNF$@#!'s Avatar
Default Re: type r or gs-r (jdm_cars)
for a street car why would you even mod a car like that for?
just get a gs and some altezzas and there you go.
Old Aug 21, 2004 | 05:29 AM
totsie7944's Avatar
It depends, I have raced a few built gsr's dragging and auto-crossing at some tracks near my house. I have never lost to a GSR. If you have the money to throw on a turbo go with the gsr. If you want a car that is fast all around when considering a daily driver go with the Type R, just because of its stock capabilities and tuning capabilities.
Hello Honda Tech
Jun 19, 2010 08:54 PM
gator1
Jun 29, 2009 08:19 AM
IntegraGuy16
May 25, 2005 07:15 AM
NA JDM GSR
Mar 8, 2005 05:04 PM
rough_draft
Aug 23, 2004 02:08 AM
