Whining noise coming from the belts...
Old Aug 20, 2004 | 10:48 PM
Broken Gearbox's Avatar
Default Whining noise coming from belts...
Well...i was driving around today (1993 Accord) and i hit a little bump going about 5mph...and i revved up my motor...and it started to make a whining noise..i pull over on the side of the road to see where its coming from and it sounds like its coming from the alt or the ps belt im not sure. When im driving it and i give it more gas it gets louder...it almost sounds like that noise your speakers make...kinda high pitch but not..what do you guys think it is? Im thinking about sparying some wd40 on the belts or maybe one of the belts is loose/tight. But i dont know.
Old Aug 20, 2004 | 11:18 PM
H2290's Avatar
Default Re: Whining noise coming from belts... (2.2L)
If it is the whining sound I am thinking of it could be P/S fluid. Check your level and make sure it didn't get mesed up or anything.
Old Aug 20, 2004 | 11:36 PM
Hmm but my ps seems to be working fine.
Old Aug 20, 2004 | 11:42 PM
Default Re: (2.2L)
well i just went to spary wd40 on the belts and it wasnt that...also the motor was still cold and the sound was louder?! and today when the motor was hot from driving it didnt sound as loud?...so im guessing one of the belts has to be loose/tight.
Old Aug 22, 2004 | 09:47 AM
matman4444's Avatar
Default Re: (2.2L)
my alt belt was doing that same **** on my explorer, but only when it was cold after it was warm it went away mostly
Old Aug 22, 2004 | 05:19 PM
C_H_A_D's Avatar
Default Re: (matman4444)
on my 99 accord it was doing the same thing it starts as soon as you start your car, it was my alternator I took it to the dealer because it was under warranty
Old Aug 22, 2004 | 11:03 PM
tjohnson329's Avatar
That noise normally means your belts are loose. The noise is probaly loud and gets louder as you dirve it is your timeing belt or accesorie belt (ALTENATOR). If the noise ges louder if you turn the whell it is your power steering belt. Another thing i wouldn't spray anything on my belts especially WD40 that it can cause your belt to slip and throw your timing off. it can also it throught the belt. that is why if you ever get a oil leak and the oil gets on the belt the replace the belt for you. so just tighten up your belts and you will be fine.
Old Aug 23, 2004 | 01:12 AM
hmm the belts seem to be fine...i hope its just the ALT.
Old Aug 23, 2004 | 09:10 AM
Elvis1977's Avatar
Spray water on each belt and see when the noise goes away. Most of the time it's the drivebelt. Replace it with a new one if necessary. Don't just tighten it up.
Old Aug 23, 2004 | 02:14 PM
supercreed2002's Avatar
Default Re: Whining noise coming from belts... (Elvis1977)
If it is a continues whining while the engine is running, it is most likely your Power Steering Belt. I replaced all my belt on my car recently and it whined when I let the engine rev higher. Sure enough, it was alt. belt. Also when you have your engine running, pop the hood and watch the belt while you have a friend rev the engine. A loose belt will viberate really bad and it's kinda hard to miss it. Refer to your Haynes manual for specific intruction to tighting up the belts.
Caleb
Old Aug 23, 2004 | 06:02 PM
joey_knuckles's Avatar
could be the ac compresser
Old Aug 23, 2004 | 07:38 PM
Default Re: Whining noise coming from belts... (joey_knuckles)
A/C Compressor doesn't make that noise(That I know of), but the A/C Compressor and Alt. are on the same belt...
bpetruzzo
24
Jul 30, 2011 03:47 AM
milanoredgsr
Feb 29, 2008 06:41 AM
preludedriversh
Jan 9, 2007 06:56 PM
coupe99vtec
12
Mar 1, 2005 11:20 AM
