momo horn install question please help!!!!
i have a 94 teggy and just installed the momo tunner with hub, my question is i got t wo horns how do i hook them up so the horn will work? also if anyone is interested in a stock teggy steering wheel with air bag and cruise control give me a offer.
Mine is a g2 but it should be similar.
Most Hondas have 2 horns but all the wiring you need should be in the hub anyway. All the horn needs is a ground to activate it; so the wire that sticks out from the hub connects to the terminal on the horn button, and the other terminal on the horn button needs to connect to a ground.
If there is a ground wire in the hub you need to connect it to that, otherwise you need to ground the wire yourself either by screwing it to the hub or by jamming it between that metal ring and screwing it down.
It's kinda hard to explain but if you have some pics I can photoshop some arrows on it to show you what I mean.
am confused? there is one wire sticking out which i already connected to th horn button, but now am confused on where i should conect the pin to, am thinking to the one of the pins on the srs socket. i need pictures to help becuase from what your telling me there are 2 grounds that go to the horn button.
Ok so there is 1 wire you found that was sticking out and that went to the horn button? If so just find another short length of wire and connect it from the other terminal on the horn button and ground it somewhere inside the hub.
Well that's the way it was on mine, did your car have an airbag? here in NZ it's illegal to remove an airbag wheel so I'm not sure what to do about that.
Chance EG
Jul 25, 2017 06:22 PM
mahatma
10
Jul 11, 2005 08:18 AM
Lamska
Jul 8, 2004 05:45 PM
jdmspoonitr
Jul 31, 2003 02:14 PM
