#!@$* Damn oil on roads... and corn..
Old Aug 20, 2004 | 08:46 PM
dk127's Avatar
Default #!@$* Damn oil on roads... and corn..
Damn it, a couple of days ago they oiled my road... I was washing my car today and found specs ALL OVER, and simple green won't take them off. I'm thinking I'll need a clay bar.
I never used a clay bar before, but all you have to do is keep the surface wet and rub in 1 direction, right?
Any other suggestions?
And coming home from work, I had corn in a box and the corn juice got over my passenger seat. I'm a bit angry about that, and I hope it doesn't smell later on. Well, its only about 1 inch by 1 inch, but I'm drunk so that can be bigger....
Old Aug 20, 2004 | 09:06 PM
Ill's Avatar
Ill
Default Re: #!@$* Damn oil on roads... and corn.. (dk127)
Go search the posts on cleaning Alcantra (our synthetic leather). Use water only, quicky, and blotting, not too much rubbing. It will come out. Corn is a simple starch -very easy to remove with water alone.
You may have to use bug/tar remover, or denatured alcohol to melt the tar. I have that problem too. Follow up w/SG, clay, and wax after.
Yes, you must lube the clay. Don't drop it either. Once dirty from hitting the ground, it's done. Some break it into 3 small pieces to make it easier to handle.
Old Aug 20, 2004 | 10:51 PM
RTW DC2R's Avatar
what the hell is corn in a box and corn juice?? must be a midwest thing?
weirdos.
Old Aug 21, 2004 | 12:51 AM
tony4311's Avatar
Default Re: (RTW DC2)
yep make sure you keep the surface lubed up at all times. If it gets dry the clay will do more harm then good. Go back and forth the same way the wind would flow if you were driving, so front to back-back to front etc.
Old Aug 21, 2004 | 05:09 AM
Opie's Avatar
What exactly does oiling a road do?
Old Aug 21, 2004 | 05:57 AM
brautzen's Avatar
Default Re: (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">What exactly does oiling a road do?</TD></TR></TABLE>
If it's a dirt road, it keeps the dust down.
Old Aug 21, 2004 | 08:31 AM
Tweakmeister's Avatar
Default Re: (opie)
keeps the squeeling down
Old Aug 21, 2004 | 11:05 AM
Dr. EKology's Avatar
Default Re: (opie)
Keeps the drifters happy.
SpeedoKing
Detailing
21
Apr 8, 2011 02:42 PM
i-VTEC_DOHC
Detailing
23
Jun 17, 2009 09:06 PM
BLUE EH3
Suspension & Brakes
11
Nov 15, 2006 01:38 PM
mr devious illusions
10
Jun 9, 2006 01:26 PM
jdmeg9
10
Oct 5, 2005 01:38 PM
