Honda S2000 Honda S2000
CTAE Carbon Fiber Intake manifold
Old Aug 20, 2004 | 07:44 PM
evil vapor's Avatar
Default CTAE Carbon Fiber Intake manifold
Car will be dyno tested and tuned on monday with results posted a few days later. Can't wait to fire it up! Hopefully things will be set tonight for a quick drive around the block. Unlike other setups out there, this one will be tested before going into production with NA results and FI results. Any FI guys want to buy one for testing? I'm going nuts over this thing, it's MUCH lighter than the stock piece.
Here are a few pics, keep in mind this is a testing unit for a NA setup, it's preproduction and is in raw form. I heard that hybrid weaves will be available for different colors. Did I say I can't wait to drive the car?
screw imagestation, click on link for pic
http://www.we-todd-did-racing....DE%3D
stay tuned for a full write up, stages of tuning, and outcome. So far, the only change since my last dyno has been this manifold. Same stock size throttle body too. Hopefully, I'll be able to get my hands on a larger throttle body in the mean time. That will be it as far as "bolt on" mods.
*Update*-10/07/04
Testing should commence next weekend, and all questions can be better answered by Tom. You can reach him at his email:
tom@ctautoengineering.com
and the website is: http://www.ctautoengineering.com
I do believe the manifolds can be ordered now and seems like pre-production has started.
Don't ask me about pricing, I'm not selling anything here nor advertising. Just direct your questions to Tom and post here what he says so we don't get redundant questions.
*Update* - 11/27/04
Was only able to test the first configuration of the manifold on the dyno. Gains seen throughout the power band except for the top where it seems to choke for air. Solution...configuration #2 which is what I'm told the final layout will be and I hope to get sorted out and dyno again shortly. I'll have dyno charts up hopefully at the end of the final testing.
Guys, the manifold is COLD to the touch even under the dyno, the intake piping and throttle body were warm due to heat transfer from the radiator, but the manifold was ice cold (not icy cold but you get what I mean).
Vtec was lowered to 5000rpm!!! If there was more time, it would've been lowered to 4800rpm with no loss in the transition or dip in the torque/hp curves.
Driving impressions: BAD ***! When you get ~16-20whp gain from 5000-6000rpm, you feel it! Especially on downshifts. I had reverted back to the stock final drive setup from running 4.77's and at first I thought the car pulled a tad bit harder than before (thinking I was still running the 4.77s). Later do I realize that I'm on the stock 4.10s and the car pulls hard! I guess the butt dyno can be useful?
Old Aug 20, 2004 | 08:50 PM
Project SSAP1's Avatar
Default Re: CTAE Carbon Fiber Intake manifold (vapor)
i sir hae made up my mind to go FI...wish i had everything done now so i could get on this bad boy and do some tests
Old Aug 20, 2004 | 09:45 PM
SimbaDogg's Avatar
Default Re: CTAE Carbon Fiber Intake manifold (Project SSAP1)
finally...i've been waiting for this forever
Old Aug 20, 2004 | 10:06 PM
Eri_S2k's Avatar
Default Re: CTAE Carbon Fiber Intake manifold (SimbaDogg)
Man looks SICK!
Dont have a Close up Pic?
Old Aug 21, 2004 | 01:20 AM
evil vapor's Avatar
Default Re: CTAE Carbon Fiber Intake manifold (Eri_S2k)
Update: wasn't able to do the road test, need to get a new intake manifold gasket as re-using the original one wasn't a good idea and there wasn't a good seal. Looks like the dyno tuning day set on monday will have to be delayed. Sorry guys.
Old Aug 21, 2004 | 05:52 AM
OC 335i's Avatar
Call me up I want to go for a ride. lol.
Looks crazy. How are the insides smooth with CF?
Old Aug 21, 2004 | 10:35 AM
PNB's Avatar
PNB
GatorNATION
Default Re: CTAE Carbon Fiber Intake manifold (JMS JT)
Looks great! Can't wait to see the results.
Old Aug 21, 2004 | 10:53 AM
SuzukaBlueAP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">Update: wasn't able to do the road test, need to get a new intake manifold gasket as re-using the original one wasn't a good idea and there wasn't a good seal. Looks like the dyno tuning day set on monday will have to be delayed. Sorry guys. </TD></TR></TABLE>
Hondata IM gasket?
(do they make one for the F20c anyways?)
Old Aug 21, 2004 | 11:42 AM
StinkyTofu's Avatar
Default Re: CTAE Carbon Fiber Intake manifold (ScreaminTeg)
Looks pretty awesome, Vapor. Could you tell us a little bit more about the manifold though? Whats the difference between this and the stock unit besides weight? Is it an exact mold? And lastly, how much do you predict the manifold will cost in production form?
Old Aug 21, 2004 | 12:22 PM
Default Re: CTAE Carbon Fiber Intake manifold (StinkyTofu)
im with the guy up top ..more info on the manifold
Old Aug 21, 2004 | 12:42 PM
PNB's Avatar
PNB
GatorNATION
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">Hondata IM gasket?
(do they make one for the F20c anyways?)</TD></TR></TABLE>
Yup
Old Aug 21, 2004 | 04:46 PM
AJ PwR's Avatar
Nice looking piece . I wonder if the runners are any bigger ? How's the finish inside ?
Old Aug 21, 2004 | 09:57 PM
Sideways's Avatar
Default Re: CTAE Carbon Fiber Intake manifold (AJ PwR)
The factory manifold weighs about 20 lbs. The CF should be less than 3 lbs. Weight savings on the drivers side in the front is generally good. Tom does nice work with the CF.
Old Aug 22, 2004 | 01:13 PM
Default Re: CTAE Carbon Fiber Intake manifold (Sideways)
Just thinking...
Is this (or going to be) a direct fit just the OEM one wherea any hoses, sensors, fittings, etc. will mount right to the CF one?
Old Aug 22, 2004 | 07:32 PM
ImportSport's Avatar
I'm really eager to see more info on this!
Old Aug 23, 2004 | 09:24 AM
mistersparco's Avatar
washuuu
Default Re: (ImportSport)
Sorry for the newb inquiry, but what positive effects would this product yield?
TIA
Old Aug 23, 2004 | 10:42 AM
jolt-tsp's Avatar
Default Re: (mistersparco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mistersparco &raquo;</TD></TR><TR><TD CLASS="quote">Sorry for the newb inquiry, but what positive effects would this product yield?
Apart from the weight savings, I'd like to know too. Waiting for the full writeup
Old Aug 23, 2004 | 11:57 AM
Default Re: (jolt-tsp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolt-tsp &raquo;</TD></TR><TR><TD CLASS="quote">
Apart from the weight savings, I'd like to know too. Waiting for the full writeup </TD></TR></TABLE>
Carbon Fiber dissipates heat (doesn't hold it). This should help keep intake air temps down.
Old Aug 23, 2004 | 11:10 PM
evil vapor's Avatar
Default Re: (ScreaminTeg)
Sorry for the delay in updates guys, I hope I'll be able to answer everyone's questions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StinkyTofu &raquo;</TD></TR><TR><TD CLASS="quote">Looks pretty awesome, Vapor. Could you tell us a little bit more about the manifold though? Whats the difference between this and the stock unit besides weight? Is it an exact mold? And lastly, how much do you predict the manifold will cost in production form?</TD></TR></TABLE>
It's not an exact mold. Runner length and plenum volume have changed. I was told the rig was tested under computer software for flow characteristics, this isn't meant to be a bling piece but it certainly has the bling factor. The manifold is VERY light, the fuel rail/injectors/throttle body seem to weigh more than the manifold. I'm not sure how much the manifold will cost. I want to abide by the same rules as everyone else and keep this thread as tech as possible, avoiding commercial advertisement. CTAE has a website, I'll get it for you guys, they also make the brake cooling duct kit and some other carbon fiber parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJ PwR &raquo;</TD></TR><TR><TD CLASS="quote">How's the finish inside ?
The finish inside seems to be smoother than stock, but this is a prototype unit and was solely made for testing purposes. I can't wait for a production piece but still have to go through the testing phase to see what the manifold can do on the dyno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">Just thinking...
Is this (or going to be) a direct fit just the OEM one wherea any hoses, sensors, fittings, etc. will mount right to the CF one?</TD></TR></TABLE>
It's meant to be a direct swap, and fit with minor changes such as the mounting of the IACV. Currently, there aren't any emissions control on my car, but the ports for it are there ie secondary air injection ports.
TIA </TD></TR></TABLE>
lol, it's okay, newb inquiry is okay. Positive effects will hopefully be more torque down low while retaining the same top end, maybe make some hp up top. Who knows, we'll see, it'll all depend on the change in air/fuel ratio and what we can tune. I'm probably more anxious than all of you to see what this thing can do, car has been down for over a month during this process.
The use of the carbon fiber is not only for weight savings but as those with the hondata intake gasket know, there's some free hp to be kept in preventing heat soak and the ill effects of hotter intake charge temps. One can only wonder about the gains of this manifold on a forced induction setup, makes me wonder why I'm sticking to NA when a beast of setup can be made here. *slaps head* yea, FI isn't allowed in honda challenge.
Anyways, I'll start the write up, with the previous tuning stages, I need to get the dyno charts from the dyno tuner which isn't an easy task. Car was putting down ~240whp at the last tuning stage.
evil vapor's Avatar
Default Re: (vapor)
also, imagestion sucks, hence the red X at the top.
Old Aug 24, 2004 | 09:21 AM
neo1z's Avatar
Default Re: (vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">also, imagestion sucks, hence the red X at the top. </TD></TR></TABLE>
Word...that red x has been upsetting me...I havent seen the pic yet
Old Aug 27, 2004 | 12:24 AM
evil vapor's Avatar
Default Re: (neo1z)
fixed the link in the first post, pick should work, just click the link, here's another shot of the manifold off the car:
Old Aug 27, 2004 | 01:57 AM
Sideways's Avatar
Default Re: (vapor)
Hey Vapor,
Is that an adjustable plenum?
Old Aug 27, 2004 | 09:24 PM
tmkpres's Avatar
Default Re: (Sideways)
The actual product will look a lot better then that one right ! Yes I know its for performance but it needs to be cleaned up a little ! (right ? )
Old Aug 28, 2004 | 07:27 AM
Rodrigo's Avatar
Wow, I'd imagine it will be way smoother than stock. Also the air temp maybe lower do to the material not heating up as much.
