Engine running hot at idle
Old Aug 20, 2004 | 06:16 PM
Ben51925's Avatar
Default Engine running hot at idle
I have a 88 prelude si that has been acting up lately. Whenever I'm sitting in traffic or at a stoplight the engine temp goes up almost to the red. As soon as I start driving it goes back down to the normal temp. Im pretty sure the fan is working fine because sometimes when I turn the car off it runs for a little while.
I checked the fluid levels and they are full. But I did notice that the cap on the overflow tank was missing. Could this cause a loss of pressure in the system and be the over heating problem?
If anyone has any ideas, let me know. Thanks.
Old Aug 21, 2004 | 09:27 AM
Ben51925's Avatar
Default Re: Engine running hot at idle (Ben51925)
Anyone?
Old Aug 21, 2004 | 10:10 AM
EuRoBrO's Avatar
No, that cap on the over flow will not affect heating at all. Sounds like you need to double check and make sure your fans are kicking on when your just sitting there. Drive your car for a little bit, pop the hood and stand there until the fans kick on. If they do not, theres your problem. They should kick on within 2 min. of sitting there after normal operating temperature. If the fans do kick on the next step that I would take is go to your local Honda dealership and get a new thermostat. That should fix your problem. If that does not work you should probably do a radiator flush and refill with new fluids. Good luck!
Old Aug 21, 2004 | 01:12 PM
Ben51925's Avatar
Default Re: Engine running hot at idle (EuRoBrO)
I just drove it and noticed that if I rev it up when Im stitting still the temp goes down. Im thinking that air or something is getting inside and the coolant isnt flowing as it should be.
Vtec04
Honda Civic (2001 - 2005)
Nov 1, 2017 04:09 AM
mdoubleg
Nov 30, 2010 03:09 PM
02blackcivic
Nov 29, 2009 12:21 PM
RAYThOM
Classic Hondas
Jun 16, 2008 10:33 AM
-[95cxhatch]-
Feb 28, 2004 08:20 AM
