Another Del Sol "?"
Ok, i normally am not the kind of people that says "search" on every post, but this can definately be found easily.
...Please search. Not just here, but you have yahoo, google, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRXDelSol »</TD></TR><TR><TD CLASS="quote">Ok, i normally am not the kind of people that says "search" on every post, but this can definately be found easily.
...Please search. Not just here, but you have yahoo, google, etc.</TD></TR></TABLE>
then give him a real answer you ***. i bet you dont even know the answer to his question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol »</TD></TR><TR><TD CLASS="quote">optional on si's
standard on VTEC's</TD></TR></TABLE>
ehhh....wrong!! my vtec sol does NOT have abs, but i do believe it is an option on si's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16vtecsol »</TD></TR><TR><TD CLASS="quote">
ehhh....wrong!! my vtec sol does NOT have abs, but i do believe it is an option on si's.</TD></TR></TABLE>
is yours a 93?
cuz, honestly, there is like no vtec 93's ever.
is yours a 93?
is yours a 93?
cuz, honestly, there is like no vtec 93's ever.</TD></TR></TABLE>
Wrong, if you want to get technical there were jdm 92/93 del sol sir's.
All bullshitting aside my 94 vtec didnt come with abs either, I believe ABS became standard in '95 on VTEC models and has always been an OPTION on si/vtec models. I could be wrong though.
is yours a 93?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerbear! »</TD></TR><TR><TD CLASS="quote">
Werd
Werd
ur right SICKSOL the 94's did not have ABS, mine doesn't, but from 95 and up they started to have ABS as standard on the VTEC models, i'm not sure of the other models
drive really fast and slam on the brakes, and if they lock up u don't have ABS
ok don't do that but i'm almost 99% sure that the sols didn't get ABS till 95, do a search on google for the del sol specs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecdelly »</TD></TR><TR><TD CLASS="quote">93 and 94 no abs half of 95 no abs... 95 1/2 through 97 abs standard on vtec optional on si</TD></TR></TABLE>
and to tell if you have ABS, look under your hood and directly behind your passenger side headlight beside the intake box there would be a box with like eight hard lines going into it and it will have a plastic resivior on it
if your car does not have that, you don't have ABS
93-94 had it as an option on both VTEC and Si, the 95-97 VTEC came with abs and still and option for the Si.
As for how can u tell, go look under your hood. if u see a mass of orange plugs (they stick out like a sore thumb) then u have abs. also if for some strage reason someone covered all the plugs follow the line from your master cyl and see if it leads to a manifold that has alot more brake lines coming out of it.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Souless »</TD></TR><TR><TD CLASS="quote"> i believe it was standard when they took away the auxilory lights??? iono might be wrong not sure </TD></TR></TABLE>
they took those lights away in 96 and that is when it became a standard on VTEC models
Modified by LSvtecEH2 at 12:01 PM 8/22/2004
1995 Honda Civic del Sol
2 Door VTEC Coupe
4 cyl 1.6 L Engine
5-Speed Transmission
Aluminum/Alloy
Wheels
AM/FM/Cassette
Audio System
Antilock Brakes
Bucket Seats
Center Console
Cruise Control
Dual Front Airbag Restraints
Intermittent Wipers
Power Brakes
Power Door Locks
Power Mirrors
Power Steering
Power Windows
Rear Window Defroster
Remote Trunk Release T
arga Top - Solid
Tachometer
Tilt Steering Wheel
Velour/Cloth Seats
http://www.partspalace.com/Hon....aspx
2 Door VTEC Coupe
4 cyl 1.6 L Engine
Aluminum/Alloy
Wheels
AM/FM/Cassette
Audio System
Antilock Brakes
Bucket Seats
Center Console
Cruise Control
Intermittent Wipers
Power Brakes
Power Door Locks
Power Mirrors
Power Steering
Power Windows
arga Top - Solid
Tachometer
Tilt Steering Wheel
Velour/Cloth Seats
Maybe I'll look into doing a conversion in the near-future.
