why is it so hard to twist the collar things on coilovers
Old Aug 20, 2004 | 01:28 PM
null.'s Avatar
Default why is it so hard to twist the collar things on coilovers
ok so i took out the strut now its really hard to twist. any one of ideas beside using the perches since i dont' have any
Old Aug 20, 2004 | 01:31 PM
99cxrico's Avatar
Default Re: why is it so hard to twist the collar things on coilovers (egb18turbo)
try using some oil or wd40 or try turning them down the threads a little as one and loosen one up
Old Aug 20, 2004 | 01:33 PM
Deemeetree's Avatar
Electrician
Lube them up. All the miles of driving probably left some debris on the sleeves and it's hard to break them loose or twist.
Old Aug 20, 2004 | 01:47 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (Dimi)
sometimes dirt gets onto the threads and it locks the perches in place. best way to prevent this is to occasionally clean any dirt off of the collar and spray wd40.
Old Aug 20, 2004 | 01:53 PM
null.'s Avatar
Default Re: (AzntaggeR)
i just installed them and took them out to try adjusting them, i wd-40'd it up still not budging.
Old Aug 20, 2004 | 02:25 PM
H.crx-si
Guest
Posts: n/a
you have 2 perches that can spin correct? their probably locked together very tightly first break them loose apart by spining each one in the opposite direction. Then adjust them seperately.
Old Aug 20, 2004 | 02:31 PM
null.'s Avatar
Default Re: (H.crx-si)
haha you make it sound so easy but i tried that but still no go. i probably need some leverage, anyone know any other tools besides perches that could be used?
Old Aug 20, 2004 | 02:41 PM
ej1 pilot's Avatar
Default Re: (egb18turbo)
you mean the ring that spins? you know you have to loosen it with a tool right...or are you talking about someting else
Old Aug 20, 2004 | 02:43 PM
null.'s Avatar
Default Re: (Art In Motion)
and the collars or whatever it's called. so i would need the tools no matter what?
Old Aug 20, 2004 | 02:57 PM
AzntaggeR's Avatar
TSPeed Factory
use an oil filter wrench and see if that works.
Old Aug 20, 2004 | 03:19 PM
ej1 pilot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egb18turbo &raquo;</TD></TR><TR><TD CLASS="quote">and the collars or whatever it's called. so i would need the tools no matter what?</TD></TR></TABLE>
what kind of coilovers do you have? for my ground controls you need an allen key to loosen the ring and turn it on the collar
as for moving the collar....just jack the car up and whack it with a BFH
Old Aug 20, 2004 | 03:22 PM
jdmitr01's Avatar
Some guys say the rock or dirt can make the collar twist hard.. I use water and soap to clean it up and then it is easy to twist.. Try it..
Old Aug 20, 2004 | 03:25 PM
null.'s Avatar
Default Re: (jdmitr01)
i have apex'i world sport coilovers i'm going to try to adjust it this weekend, as of now i'm rolling with the rear really low and the front semi high lol but i think i'm going to try the screwdriver and hammer method again because i think i hit it the wrong way (to the right lol)
fpvteg0681
Jul 25, 2010 07:29 AM
anth2k4
Suspension & Brakes
Mar 26, 2009 11:15 AM
koulaid
Jun 2, 2008 10:00 AM
violence_hero
Nov 1, 2005 10:34 PM
lsvtec101
Suspension & Brakes
31
May 25, 2005 08:52 AM
