Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
KAAZ LSD chatter
Old Aug 20, 2004 | 01:26 PM
JAMinCiViC's Avatar
Default KAAZ LSD chatter
I had a question on the KAAZ LSD. I read somewhere it has a minor chatter on slow turns. I had one installed and it shakes the whole front end. Is this normal? I did install motor mount inserts also.
Thanks
Old Aug 20, 2004 | 02:06 PM
Dan GSR's Avatar
Default Re: KAAZ LSD chatter (JAMinCiViC)
its normal
feels like your car is broken at low speed
Old Aug 20, 2004 | 02:29 PM
The Internet Tough Guy's Avatar
Default Re: KAAZ LSD chatter (Dan GSR)
what fluid are you using?
sounds like you're using the honda mtf. this is what happened to a friend. we thought it was a quaife, but it actually was a kazz. put in honda mtf and dear god the front half of the car was shaking terribly. switched to the right fluid and it's fine.
you need the kazz fluid or 80-90 gear oil. do a search.
also you need to break it in with the proper fluid by doing figure 8s for about 1/2 hour.
Old Aug 20, 2004 | 03:10 PM
JAMinCiViC's Avatar
Default Re: KAAZ LSD chatter (jwn7)
Thanks for the help!!!
Old Aug 20, 2004 | 03:20 PM
Mike P.'s Avatar
25 Year Member
Yes, sounds like a lubrication issue. My BMW's diff (which I believe to be a clutch-style diff) does this at parking lot speeds (not autocross ), although the ruckus comes from the "correct" end of the car (paging tnord).
A fluid change later and it was a night and day difference.
Old Aug 21, 2004 | 05:59 AM
JAMinCiViC's Avatar
Default Re: KAAZ LSD chatter (Mike P.)
Its 80-90w oil in there. I guess with addition to the motor mount inserts it just amplifies the shake a little more. I will go ahead and purchase KAAZ oil and see if it tones it up a bit.
Old Aug 24, 2004 | 09:19 PM
MAD ITR 55's Avatar
I have also had this same problem on a past civic of mine. I did figure 8's for 1 1/2 hours to break mine in. Then after that I changed out the KAAZ fluid and put it fresh. The chatter/bumping wasn't that noticeable at first,but right before I took it out of the civic it seemed like it was the worst. I thought I might have chipped a tooth on the ring gear and maybe that was causing the chatter/bumping when turning the wheel. After seeing this post it seems like this is normal for the KAAZ lsd's. I still wanna pop the case off and take a look. I plan n selling the tranny to a friend and I don't want it to be bum when he gets it .
Old Aug 24, 2004 | 11:55 PM
Wai's Avatar
Wai
ProFunction/GT Motoring
The clanking sound is absolutely normal for a clutch type LSD. Fluid can definitely makes a difference, but it won't eliminate the sound. If you understand how LSD works, you would know where the sound is coming from.
If your car is mostly daily driven (lots of slow speed turns like in a parking lot or local street), a clutch type LSD would be worn out pretty quickly.
ac26
Transmission & Drivetrain
Apr 8, 2010 09:31 PM
oramac_eg
Oct 5, 2008 01:57 PM
crxhybrid1320
Mar 9, 2006 01:44 PM
Atomic EG
Aug 5, 2005 05:08 PM
doublejz
Oct 6, 2003 05:18 PM
