EG GSR Brake Conversion--HELP!!!!
Old Aug 20, 2004 | 01:19 PM
EJ2_B16's Avatar
Default EG GSR Brake Conversion--HELP!!!!
Car: 1994 Honda Civic DX
Problem: Prop Valve, Master Cylinder, Brake Booster????
I swapped over to GSR front and rear brakes. My question is, which prop valve and master cylinder do I need.
I know it's suppose to be a 40/40, but off what year car and abs or non-abs. Also, Is it necessary that I swap over the master cylinder to 15/16 and GSR brake booster too?
Old Aug 20, 2004 | 01:28 PM
Sasebonian's Avatar
Default Re: EG GSR Brake Conversion--HELP!!!! (EJ2_B16)
the prop. valve from a 89-91 integra LS/RS/GS will work. They had 4 wheel disc brakes with NO ABS. I can't remember if that's the correct years, but it's the generation of integras before the 94-01.
Old Aug 20, 2004 | 01:37 PM
EJ2_B16's Avatar
Default Re: EG GSR Brake Conversion--HELP!!!! (Sasebonian)
Thanks for the reply. But what about the MC/Booster. Which ones do I need, off what car?
Old Aug 20, 2004 | 01:47 PM
fakemike's Avatar
You can use the MC from a 91 civic four door EX.
Its a 15/16ths MC. It costs about $50 (with core) at your local auto parts store. With this MC you don't need to move any brake lines.
I not sure if you need to get a different prop. for the four wheel disks
Old Aug 20, 2004 | 02:23 PM
EJ2_B16's Avatar
Default Re: EG GSR Brake Conversion--HELP!!!! (fakemike)
Thanks..
Old Aug 20, 2004 | 02:34 PM
GS-Rcivic's Avatar
I have a GSR booster and MC if you want, let me know.
swallow
11
Aug 7, 2010 09:14 PM
o5mar1
Jun 12, 2006 07:05 PM
ares650
26
Feb 19, 2004 10:08 PM
CWESTINAP1
Sep 10, 2003 02:45 PM
